CzarDestructo Posted March 23, 2011 Share Posted March 23, 2011 So I’ve been noticing for the last few months that my car, on some days, has an issue with the idle RPM detection. Only when my car is in gear if I feather the throttle in traffic the RPMs have a tendency to droop a little too low when returning to idle and the car stutters a second and the RPMs pick back up and everything is fine. What could cause this, possibly an aging sensor, gummed up throttle body, maybe it’s the transmission itself, etc? Any thoughts? 2008 Legacy 2.5i, 4EAT, approximately 90k miles Link to comment Share on other sites More sharing options...
burnout8488 Posted March 23, 2011 Share Posted March 23, 2011 This happens to all of us at one time or another. Usually only when the car is cold. Link to comment Share on other sites More sharing options...
Monwells Posted March 24, 2011 Share Posted March 24, 2011 My legacy does this when its cold. Drop it into Neutral when you stop and it all goes away. Link to comment Share on other sites More sharing options...
TRSCobra Posted March 26, 2011 Share Posted March 26, 2011 I'm not too familiar with newer subarus, but I'd check/clean the throttle body and especially the idle air control valve. If the IAC gets clogged up, the engine will get choked a bit when you first let off the gas, then when the computer senses the low idle speed, it opens it up more to prevent it from stalling. Also could be a torque converter lockup issue. Link to comment Share on other sites More sharing options...
