Al Thomson Posted March 23, 2011 Share Posted March 23, 2011 anyone got god pictures of removing the trim around the gear stick? I swear to god i got a loose screw that mounts the radio and cant get to it with out removing this trim first. Thanks. Link to comment Share on other sites More sharing options...
rice_rocket Posted March 23, 2011 Share Posted March 23, 2011 Emmm... well if it's the same as my 5eat, you pry the chrome rim out first, then the rest pops out/unscrews slowly... Link to comment Share on other sites More sharing options...
Al Thomson Posted March 23, 2011 Author Share Posted March 23, 2011 i think its different because of the boot. Some have said pull back and up...not sur ehow hard to pull Link to comment Share on other sites More sharing options...
2005legacy2.5i Posted March 23, 2011 Share Posted March 23, 2011 like others have said put your hands down on the boot and pull up/ back, it's easier than you think. I'm pretty sure you can't break anything Link to comment Share on other sites More sharing options...
ssbtech Posted March 23, 2011 Share Posted March 23, 2011 To get to the radio screws you will have to remove the trim beside the radio. You'll need to remove the shifter trim and the parking brake boot or you will scratch the finish on the parking brake boot when you go to remove/reinstall the left side trim. You'll want a flashlight and a long flat screwdriver to remove the parking brake boot. Easier to sit in the passenger seat. Pull up on the parking brake boot (part closer to the back of the car). It will come free from the center console but there will still be a clip holding it at the lower front. This is where you will want a little flashlight and your long screwdriver. Once you can see the clip, use the screwdriver to unhook the lower-front clip. Then you can pull the parking brake up over the handle (leave it on). Now you can pull up the shifter trim and get to the screws holding on the side pieces. Link to comment Share on other sites More sharing options...
Al Thomson Posted March 23, 2011 Author Share Posted March 23, 2011 Thanks, I managed to get the shifter trim off today while on lunch. Just got brave and pulled hard. I need to look closer now because I thought the side trim pieces were held by screws at the bottom and clips up the side of the radio. Guess I will find out this weekend. Link to comment Share on other sites More sharing options...
ssbtech Posted March 23, 2011 Share Posted March 23, 2011 Screws at the bottom, clips at the top. Link to comment Share on other sites More sharing options...
