SuperhawkLGT Posted March 20, 2011 Share Posted March 20, 2011 Just scored a good deal on some wheels for my daughters Altima but the offset is a little too high 50mm. I need to be closer to 42mm so I am looking for some spacers. What do you guys recommend? Do I need to worry about the hubcentric stuff, I am thinking it's not too big a deal. Anyone dealt with these guys? http://www.ezaccessory.com/5_Lug_Wheel_Spacers_s/58.htm Link to comment Share on other sites More sharing options...
sheppo9 Posted March 20, 2011 Share Posted March 20, 2011 That link won't load for me, I've used and like http://novustech.ca/. Are they anything like Subaru's, where if you use over a 5mm spacer, the lug won't seat far enough? If so, you'd need bolt-on spacers, and depending on how long the standard studs are, you might have to grind/cut the standard studs. Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted March 20, 2011 Author Share Posted March 20, 2011 $45 each!!! Holy cow! Link to comment Share on other sites More sharing options...
mr_luv Posted March 21, 2011 Share Posted March 21, 2011 I used Ichiba V2 bolt on my G35X 19x9 19x10 yes on a AWD car for a good 4 months. I had 10MM spacers up from. Same rolling diameter front and rear. Mr.350 Link to comment Share on other sites More sharing options...
sheppo9 Posted March 21, 2011 Share Posted March 21, 2011 $45 each!!! Holy cow! It's for a pair, I had to double check when I ordered mine. Link to comment Share on other sites More sharing options...
