Madjik_Man Posted March 9, 2011 Share Posted March 9, 2011 Regarding the front windshield: My driver's side wiper fluid sprayer seems to have gotten out of whack a bit (probably from the few rare iced up mornings this winter). It now mostly sprays on to the top 1/3rd of the windshield and on to the roof. Is there any way to adjust this back to normal? It seems as though it's just a flexible tube with the nozzle at the end of it. I can push it down a bit but it just seems to go back up. Any advice is appreciated. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted March 9, 2011 Share Posted March 9, 2011 Are you sure the nozzle isn't just partially clogged and screwing up the spray pattern? Link to comment Share on other sites More sharing options...
Madjik_Man Posted March 9, 2011 Author Share Posted March 9, 2011 Are you sure the nozzle isn't just partially clogged and screwing up the spray pattern? I've cleaned the car a few times since. Took a good look at the nozzle and see nothing. The spray pattern itself is a perfect fan. Just about 8-10" too high now. Link to comment Share on other sites More sharing options...
LongHiway Posted March 9, 2011 Share Posted March 9, 2011 Never messed with my Subie. On other cars, stick a pin in the center and sort of pull / lever down. The Subie has a small grid (to fan out the spray?), I'd stick a pin in the center and tilt downward. Link to comment Share on other sites More sharing options...
Madjik_Man Posted March 10, 2011 Author Share Posted March 10, 2011 It's more of a straight notch as you would find on the head of a flat screw http://i65.photobucket.com/albums/h218/madjik_man/Subaru/P1080509.jpg Link to comment Share on other sites More sharing options...
Mr. Sinister Posted March 10, 2011 Share Posted March 10, 2011 If there isn't a bent clip, hose, or loose something that causing the misalignment, I'd just wedge something in there to get it spraying in the right location. Link to comment Share on other sites More sharing options...
Madjik_Man Posted March 12, 2011 Author Share Posted March 12, 2011 Well, I have to do something. With the sunroof open yesterday my daughter, in the back seat, got a wiper fluid shower. Link to comment Share on other sites More sharing options...
