Cornelius Posted June 5, 2011 Share Posted June 5, 2011 So what was broken here? The wire had a connector inside the insulation what has been gone bad. I won't think it could be possible to get any water there, but the copper had turn into a green dust. The place where mine was broken was nearby that floor vent. Now i get healthy 12.2 Volts there instead of 0 Volts or 8-9Volts Check your grounding wire first (black one in the connector) against the ground with ohm meter, then measure the plus power cord (white with green line) on mine. Strip a little from a bad wire and replace it with a fresh one, then enjoy solving this. I believe this has been a callback in states around 2005 or something.. http://dl.dropbox.com/u/5135810/s%C3%A4hk%C3%B6vika/problem4.jpg Link to comment Share on other sites More sharing options...
Kreamer67 Posted June 6, 2011 Author Share Posted June 6, 2011 i found my activity for the day. btw. did this solve both seats or just one? because i DID have an issue with water under the carpet before. Link to comment Share on other sites More sharing options...
Cornelius Posted June 6, 2011 Share Posted June 6, 2011 Well you found your activity for the tomorrow also, i believe the same circuit is at passengers side, i discovered this late yesterday night Haven't rip any insulations of the wires off, but with a voltage meter it says 0,0Volts. So same problem i believe. Link to comment Share on other sites More sharing options...
Kreamer67 Posted June 7, 2011 Author Share Posted June 7, 2011 LOL. oh wow. so the problem happens at the connector under both seats and not at a central location... makes sense..looks like i found my LONG project for today.... nap time got in the way of that yesterday. Link to comment Share on other sites More sharing options...
Cornelius Posted June 18, 2011 Share Posted June 18, 2011 Today i fixed the both seats, there was a 2 loose wires in driver side. Earlier i just noticed one, So solder and insulate these all wires again, those are White with green lines. Link to comment Share on other sites More sharing options...
lucas569 Posted July 25, 2011 Share Posted July 25, 2011 cut my black harness and wired up 12v switched power. now it works.... Link to comment Share on other sites More sharing options...
