torinalth Posted March 5, 2011 Share Posted March 5, 2011 so, this all started 3 days ago. just happened to notice that the clutch pedal was a bit mushy at the top. next day noticed it was engaging all the way at the bottom, and now its hard to get into first, and all the other gears hesitate a bit before going in as if the pedal is not in far enough.... stock clutch as far as I can tell, and 89k. even if the clutch is going out, it would simply stop holding, not change the engaging point. I checked the res and its at the max line. any idea what may have changed to cause it to happen spontaneously? T Link to comment Share on other sites More sharing options...
m sprank Posted March 5, 2011 Share Posted March 5, 2011 Bleed fluid. Link to comment Share on other sites More sharing options...
torinalth Posted March 5, 2011 Author Share Posted March 5, 2011 thats it? Link to comment Share on other sites More sharing options...
m sprank Posted March 5, 2011 Share Posted March 5, 2011 First thing I would try. Flush the fluid. Link to comment Share on other sites More sharing options...
torinalth Posted March 7, 2011 Author Share Posted March 7, 2011 bled the system today.... the fluid was orange still just as mushy, but not engaging as low, and so far back to being normal at shifting. not perfect, but better. Link to comment Share on other sites More sharing options...
