franklin Posted May 20, 2005 Share Posted May 20, 2005 Tried to do a search. Cant find any info. What is the weight of the stock '05 LGT 17" wheel. I believe the the other specs are +55 offset, 7" width and 56mm hub size. Dont recall and cant find a stock weight. Anyone that can confirm a weight thanks. Franklin Link to comment Share on other sites More sharing options...
illt3ck Posted May 20, 2005 Share Posted May 20, 2005 20.5lbs Link to comment Share on other sites More sharing options...
Xenonk Posted May 20, 2005 Share Posted May 20, 2005 did you type in your search "stock wheel weight"? I came up with over 10 threads with the answers, here's one of them: http://legacygt.com/forums/showthread.php?t=5019&highlight=stock+wheel+weight Keefe Keefe Link to comment Share on other sites More sharing options...
franklin Posted May 20, 2005 Author Share Posted May 20, 2005 did you type in your search "stock wheel weight"? I came up with over 10 threads with the answers, here's one of them: http://legacygt.com/forums/showthread.php?t=5019&highlight=stock+wheel+weight Keefe I think I did. Tried a few ways - likely my screw up. Thanks for the help guys. (Im working a string of 12 hr. night shifts. Could be clouding my mind) Franklin Link to comment Share on other sites More sharing options...
hotrodwagon Posted May 20, 2005 Share Posted May 20, 2005 With a stock tire, 42.5 lbs. Link to comment Share on other sites More sharing options...
