Scanyland Posted February 26, 2011 Share Posted February 26, 2011 So I can get a good deal on a set of 17" rims with tires for my 96 Legacy Brigton, I'm wondering what am I looking at for clearance, between the top of the wheel and the wheel well? Link to comment Share on other sites More sharing options...
johnegg Posted February 26, 2011 Share Posted February 26, 2011 google ''miata tire calculator'' and you can plug in different tire sizes to se how they compare to yours. you can go a little wider than stock but not a lot taller. the spring perch will get in the way and the fronts will rub in turns. Link to comment Share on other sites More sharing options...
Drift Motion Posted February 26, 2011 Share Posted February 26, 2011 if you use a correct tire size for the 17" wheel, the clearance is the same Link to comment Share on other sites More sharing options...
ricky santana Posted March 1, 2011 Share Posted March 1, 2011 Not too sure about rims but if you want tires for 17'' wheels then you can do 215/45's, 225/45's (my personal favorite) OR 225/50's. The 225/50 is the tallest & widest you can go on stock suspension. The 225/45 gives you great traction with a nice low profile. The 215/45 works but seems to small in my opinion unless your dropped on coils. Link to comment Share on other sites More sharing options...
Scanyland Posted March 1, 2011 Author Share Posted March 1, 2011 Not too sure about rims but if you want tires for 17'' wheels then you can do 215/45's, 225/45's (my personal favorite) OR 225/50's. The 225/50 is the tallest & widest you can go on stock suspension. The 225/45 gives you great traction with a nice low profile. The 215/45 works but seems to small in my opinion unless your dropped on coils. Thanks, thats good to know because the tires are 225/45 so that is most good news. I did do a test fit and they did fit, looked bigger but not by much. I will find out how they work after this dam snow is gone. Link to comment Share on other sites More sharing options...
daddywagon Posted March 1, 2011 Share Posted March 1, 2011 Im running 225/50s on my outback and its lowered on teins stechs, I do have some rubbing on the wheelwell in the rear on tight turns but not much. here is a pic. http://i54.tinypic.com/24xhnx3.jpg Link to comment Share on other sites More sharing options...
Scanyland Posted March 1, 2011 Author Share Posted March 1, 2011 Then I should be golden, thanks for the help Link to comment Share on other sites More sharing options...
