jim malach Posted May 19, 2005 Share Posted May 19, 2005 when I go around a tight right turn or merging from an of ramp going to the right just had wheel bearing replaced did not help Link to comment Share on other sites More sharing options...
OCDetails Posted May 19, 2005 Share Posted May 19, 2005 Check your lug nuts. If your lug nuts aren't tight then you'll get that sound. You'll get it more than just cornering though. Also check the inside of the wheel well for rub marks. Are you using the stock wheels and tires or have you put bigger wheels on? _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
jim malach Posted May 19, 2005 Author Share Posted May 19, 2005 no stock wheels a tires when i'm at a light and make a right hand turn and turn the steering wheel quick it really makes the sound what pound should they be tighten to thanx:) Link to comment Share on other sites More sharing options...
OCDetails Posted May 19, 2005 Share Posted May 19, 2005 I don't know. You'll have to ask Subaru that one. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
SBT Posted May 19, 2005 Share Posted May 19, 2005 jim malach, You said you had a wheel bearing replaced. Did they get the CV boot back on correctly? I've actually had a CV boot that was not properly attached at the CV joint side and it rubbed/scrubbed around the periphery of the CV joint face until it was replaced. Also, it's possible they over- or under-tigtened the bearing and it's grinding in it's races. Did they reattach the inside fender skirt correctly and/or is possibly rubbing on the axle, wheel area? WRT - wheel lug nut torque specs, check out this link http://legacygt.com/forums/showthread.php?t=12613. You'll find the answer... believe about 80-85 lb ft of torque... which seems high but not overly so since all of my other Subes are in the 72-75 lb ft range. Just a couple of thoughts. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
jim malach Posted May 19, 2005 Author Share Posted May 19, 2005 thanx for the info check it out today:) Link to comment Share on other sites More sharing options...
