Heedz Posted March 16, 2011 Share Posted March 16, 2011 hmmm i hate no issues whatsoever, everything from an 04, yeah its a little front biased but i like the feel of them better than the stock calipers. Link to comment Share on other sites More sharing options...
BAC5.2 Posted March 16, 2011 Share Posted March 16, 2011 You would be able to SEE that it was helicoiled. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
wpmarky Posted March 17, 2011 Share Posted March 17, 2011 looks like the passenger side uses both of the longer STI bolts that say "9" on it. Only the driver's side lower caliper bolt says "10". I'll try cleaning out the threads to see if that helps. Link to comment Share on other sites More sharing options...
AZP Installs Posted March 18, 2011 Share Posted March 18, 2011 That is pretty suspect. All the bolts should be the same. Also you rather have grade 10 rather than grade 9 bolts holding your calipers onto your car. -mike http://www.pbase.com/paisan/image/91072632.jpg AIM: AZP Installs | E-mail: paisan@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 "Race Tested, Enthusiast Approved!" Link to comment Share on other sites More sharing options...
GTLEGACY007 Posted March 22, 2011 Share Posted March 22, 2011 Did you try chasing the threads on the bolt to make sure it ran free? Are you sure it's the correct bolt? I used the STI bolts and had no trouble. Well, I did put an extra washer in between the caliper and knuckle like an idiot, but I fixed that. LINK So there should be washers on the calipers at then knuckle? Going to be doing this soon, and I don't think the brembos I have came with any washers. I've got the sti specific bolts Link to comment Share on other sites More sharing options...
Hugo L. Posted March 22, 2011 Share Posted March 22, 2011 My stock brakes sucked so bad it was dangerous. I now have Carbotech AX-6 and they're great, aside from the squealing. Unbearable in the summer, and I'm a patient guy about that. I'm gonna go with something different the next time out. Link to comment Share on other sites More sharing options...
