lee07 Posted February 19, 2011 Share Posted February 19, 2011 So I just put in new rotor and pads on the back. I drove it for a week not knowing the new outside pads had 2 little nipples on them causing the caliper to not close/sit properly thus biting only the bottom portion of the rotor. This was why the new rotors had deep pad bite marks on the bottom 1/4 of the rotor. I had the nipples removed and now there's rust marks on where the deep pad bites were! Now will the rust eventually go away if I keep driving it? I don't have pics but the bottom portion of the rotor is shows rust. I can remove a little by hand but would the pads clear the rust away. It's been a couple day's and the rust is still there even will some hard braking! One other question. Does it matter which side the outer brake pad goes on? Link to comment Share on other sites More sharing options...
el5y Posted February 19, 2011 Share Posted February 19, 2011 I'm pretty sure it will be fine. Because of the deep bite marks the rust is probably just in there deep. When you get down to that level it will eventually rub away. Link to comment Share on other sites More sharing options...
lee07 Posted February 19, 2011 Author Share Posted February 19, 2011 Yeah, I think you're right. It is starting to clear up a little bit here and there! Link to comment Share on other sites More sharing options...
