laxdudeee Posted February 18, 2011 Share Posted February 18, 2011 I just replaced my wheel bearing, and after having it sit for two days it has now developed an oil leak. I can both see and smell smoke coming from the passenger side of the engine, it looks like it is being burned on the up-pipe near the front O2 sensor. Other relevant facts: Just replaced turbo - I got under the car and it doesn't seem to be coming from the oil return or feed lines Changed oil - Penzoil platinum w/filter, isn't leaking from the filter of drain plug It didn't smoke right after replacing the turbo, probably 2 weeks worth of driving Checked oil level, its right at F Are there any common leaks from that area? Could it be coming from the valve cover? I can see some fresh oil in the area but not the source, its a little cramped in that area. Basically I am looking for more possible sources, I am relatively unfamiliar with this engine. Link to comment Share on other sites More sharing options...
underpowerd Posted February 19, 2011 Share Posted February 19, 2011 Could it be coming from the valve cover? could be -- if it is, it could be dripping down the uppipe, check the VC at the rear (that's where mine currently has sprung a small leak, for exactly the same symptoms as yours). you could also have damaged the half-moon rear cam seal removing/replacing the uppipe; that's a bit harder to get a visual on. good luck. Link to comment Share on other sites More sharing options...
