My Car Posted February 16, 2011 Share Posted February 16, 2011 I JUST finished putting all of my engine components back on and I just started my 94 legacy for the first time in months. I had the right head rebuilt slightly and a new gasket put on. Engine is now running smooth for the most part but there is an unnerving clicking sound. got a new timing belt with 3 white marks on it. we lined up two of the marks with the tdc marks on both of the cam sprockets and the middle mark with one that was right over the engine sprocket. now there was an arrow on the engine sprocket that didnt line up with the belt mark but the engine had never turned after we took the old belt off so i thought it best to not turn the engine to meet the mark on the belt. also, we were never quite sure of the torque specs on the cam shaft retainer things. http://dl.dropbox.com/u/2882204/Pictures/subaru%20pics%20035.jpg this is not my photo but its the bolts that are boxed in red. we torqued those down to 70 to 90 in-lbs as stated by the book for the 2.5 engine. it didnt say anything about the 2.2 so we went this those specs. could this be a problem? maybe causing the clicking sound? or is it bad timing? the engine runs fairly smooth and all cylinders are firing. Link to comment Share on other sites More sharing options...
Baddog Posted February 17, 2011 Share Posted February 17, 2011 8.7 ft-lbs I had to ask the same question or 104.4 in-lbs http://img819.imageshack.us/img819/7162/ej22.jpg Link to comment Share on other sites More sharing options...
My Car Posted February 17, 2011 Author Share Posted February 17, 2011 WOW REALLY!? thanks, man. i guess i could take the valve cover off and re torque them or do you think its not that big of a deal? i remember torquing to about 10 ftlbs maybe a little less. Link to comment Share on other sites More sharing options...
Baddog Posted February 17, 2011 Share Posted February 17, 2011 I am anal about making sure things are on properly especially in the engine. Link to comment Share on other sites More sharing options...
subikid90 Posted February 17, 2011 Share Posted February 17, 2011 Same here. Did you make sure the valve lash is correct also? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Baddog Posted February 17, 2011 Share Posted February 17, 2011 I have HLA's. Mine are self adjusting. Not sure what year his are if they are 94 they are as well. Link to comment Share on other sites More sharing options...
My Car Posted February 17, 2011 Author Share Posted February 17, 2011 well i just heard from someone that the clicking could be coming from the lifters because some component needs to be filled with hydrolic fluid but its not harmful. now i dont think that the guy who cleaned and rebuilt the head did that but he also didnt say that i had to. it still clicks persistently but runs fine for the most part. a bit sputtery at a take off from a stop light. im gonna at some fuel injector to my next tank of gas. thanks for the responses guys. Link to comment Share on other sites More sharing options...
johnegg Posted February 17, 2011 Share Posted February 17, 2011 your car has HLAs, hydraulic lash adjusters, they need to pump up before they get quiet. this is pretty common when swapping in 95 - 96 ej22 into outbacks or GTs especially if the engine has been sitting for a while. the 90 - 94 ej22s have them too. it is a great adjuster since it never needs adjusting. let the car idle in the drive way for an hour a day until it gets quiet. it may take several days. if they don't quiet down after a few days you may have to pull them out and bleed them and or replace them. they can get clogged up and dirty or leak which will make them noisy. they run $25 each at the dealer or $19 online. i have some if you need them. Link to comment Share on other sites More sharing options...
My Car Posted February 18, 2011 Author Share Posted February 18, 2011 what about just driving it for an hour a day? i also put some ATF in with the oil cuz i was told that helps the hydraulic things fill up faster or something. thanks for the advice. Link to comment Share on other sites More sharing options...
johnegg Posted February 18, 2011 Share Posted February 18, 2011 you can drive it but idling is less stressful and by letting it idle in addition to driving it it should clear up sooner. the ATF will help ''clean'' the engine a bit. but i wouldn't leave it in for 3k miles. change it at 1000 miles or so. you can always do it again if you want. Link to comment Share on other sites More sharing options...
My Car Posted February 18, 2011 Author Share Posted February 18, 2011 ok thanks everyone. i think it MIGHT be getting quiter or maybe im just getting used to it. on an unrelated note: a while back a rubber hose on my heater core burst and i have since replaced it but just as i was driving it today i heard it hissing and water got all over the floor. *facepalm* ITS ALWAYS SOMETHING WITH MY CAR. oh well guess im gonna tear apart the dash again. Link to comment Share on other sites More sharing options...
My Car Posted March 21, 2011 Author Share Posted March 21, 2011 just thought I'd report that the clicking has stopped. pretty happy about that Link to comment Share on other sites More sharing options...
subikid90 Posted March 21, 2011 Share Posted March 21, 2011 Thats good to hear. you get the heater core hose all fixed? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
