PearlBlueGT Posted February 15, 2011 Share Posted February 15, 2011 I noticed my 05 LGT is leaking oil. Oil filter is dripping oil from the bottom of it and also where timing belt cover is, seems like its leaking from there and it's dripping on hot exhaust and burning off. Do I have to take off timing cover and look at oil pump, are they prone to leaks on this car? Link to comment Share on other sites More sharing options...
MDW25gt Posted February 15, 2011 Share Posted February 15, 2011 Mine is doing the same. I just got the car and they were supposed to have changed a cam seal. I dont see evidance that the entire timing cover was removed. The cover on the drivers side is all cleaned up. I dont see how they could do a cam seal without removing the entire coved and pulling the pully. Mine seems to be leaki ng the same as yours. Sorry I cant be more help, but I am interested in the fix. Link to comment Share on other sites More sharing options...
PearlBlueGT Posted February 16, 2011 Author Share Posted February 16, 2011 How hard to do cam seals and how much is shop rate to do them Link to comment Share on other sites More sharing options...
jmatijas_gt Posted February 16, 2011 Share Posted February 16, 2011 anyone find the solution to the problem? Link to comment Share on other sites More sharing options...
VermontGT Posted February 20, 2011 Share Posted February 20, 2011 The solution to the problem is to replace the camshaft and crankshaft oil seals. Timing belts on Subarus shouldn't be much more than 5 hours at a maximum, and that should include installing idlers, water pump, all seals, etc. Dealer timing belt service may be more like 2.3 hours but keep in mind that most dealers will only replace the belt itself and sometimes idlers. They don't necessarily replace the tensioner without the customer specifically requesting it. Go figure. Link to comment Share on other sites More sharing options...
