jackal8788 Posted May 21, 2015 Share Posted May 21, 2015 Autozone has (or at least the did have) some LED's that are a brighter blue. I did all my own interior lights so I don't know how close they match the factory kit, but they might be worth looking at. I can't seem to find them on the website but I've seen them in the store before. VF54 to 20G to VF54 to 18G build thread Link to comment Share on other sites More sharing options...
dfoley4 Posted May 22, 2015 Share Posted May 22, 2015 Autozone has (or at least the did have) some LED's that are a brighter blue. I did all my own interior lights so I don't know how close they match the factory kit, but they might be worth looking at. I can't seem to find them on the website but I've seen them in the store before. Thanks! I'll look into those. Also, in regards to the reversal of dimming I was running into, SVXdc was able to help me (as always). Turns out the dimmed signal is a pulse width modulation rather than an analog voltage variation. See his post here for details: http://forums.nasioc.com/forums/showthread.php?p=39156372#post39156372 Link to comment Share on other sites More sharing options...
mas102589 Posted August 7, 2015 Share Posted August 7, 2015 I used the blue lights for two reasons. 1) Yes the down light that came with the car is blue to start with. So I wanted to match that and that's what the factory kit is as well. 2) I had Red down lights in my former A6 and wanted to do something different from that car. Yes the red is cool too and it doen't effect your night vision, but I think that the output of these lights is so small and none of them are directed at your eyes squarely, so your night vision should remain the same.<br /> <br /> And blue is Techie Cool! <br /> <br /> Also, I dug into the blue down light installed in the dome light area and removed the factory Neutral Density filter that sits right in front of the Blue LED. The light now actually lets you see things in that area. Before it was just a dim, faint blue glow. How do I remove this nuetral density filter? Sent from my HTC One using Tapatalk Link to comment Share on other sites More sharing options...
mas102589 Posted August 7, 2015 Share Posted August 7, 2015 I used the blue lights for two reasons. 1) Yes the down light that came with the car is blue to start with. So I wanted to match that and that's what the factory kit is as well. 2) I had Red down lights in my former A6 and wanted to do something different from that car. Yes the red is cool too and it doen't effect your night vision, but I think that the output of these lights is so small and none of them are directed at your eyes squarely, so your night vision should remain the same. And blue is Techie Cool! Also, I dug into the blue down light installed in the dome light area and removed the factory Neutral Density filter that sits right in front of the Blue LED. The light now actually lets you see things in that area. Before it was just a dim, faint blue glow. How did you remove the neutral density filter? Sent from my HTC One using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted July 4, 2017 Share Posted July 4, 2017 Picked up a cupholder with the plexi ring a few months back from another member here. My first go at it with some small chip LEDs didn't go well, plus they were too bright. On my second try I wired it up with these, now all I have to do is splice into the harness. Used Molex connectors so that I can unplug it from the harness when removing the console cover. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Subaro11 Posted May 3, 2018 Share Posted May 3, 2018 Great mod thanks for the info. What are the colors of the seat heater control wires you tapped. How did you wire it, if you used the plug for power? LIGHT IN THE CUBBY I found there is a rubber plug in top of The opening under the climate controls. I ran a wire to the glove box light for power and on with night lights. Found a rubber plug I had that fit the hole, stuck the wire through it. Made like a recessed light. Fed wire back above glove box taped there, then left through hole on left side of box rear. Then through radio opening. Had to pull radio, nav trim, like when you remove radio. Blew the fuse once, was number 18 under the hood. Allumination, 10amp. Used thin hard wire to do the fishing through, then pulled wire. Link to comment Share on other sites More sharing options...
ZFergy87 Posted March 22, 2020 Share Posted March 22, 2020 Great mod thanks for the info. What are the colors of the seat heater control wires you tapped. How did you wire it, if you used the plug for power? LIGHT IN THE CUBBY I found there is a rubber plug in top of The opening under the climate controls. I ran a wire to the glove box light for power and on with night lights. Found a rubber plug I had that fit the hole, stuck the wire through it. Made like a recessed light. Fed wire back above glove box taped there, then left through hole on left side of box rear. Then through radio opening. Had to pull radio, nav trim, like when you remove radio. Blew the fuse once, was number 18 under the hood. Allumination, 10amp. Used thin hard wire to do the fishing through, then pulled wire. Purple /silver = red wire Black / yellow=blk wire Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted March 24, 2020 Share Posted March 24, 2020 ^^ Thanks for that ^^ !!! You've reminded me I need to finish this project. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
