schastleevo Posted February 14, 2011 Share Posted February 14, 2011 I have a blown turbo in my '05 Legacy GT. I was going to replace the turbo with the 16G I ordered from BNR racing. I was finally able to get all the parts together to start to work on the car Thursday. I was able to get the intercooler, & the heat shield off before I shot the nuts & bolts with PB Blaster. I returned to the car Friday taking off almost alll the nuts & bolts to remove the turbo. I couldn't get to the one under the down pipe, so I put the front end up on some jack stands & looked at the nuts holding the down pipe to the next pipe but didn't like what I was seeing. When the dealer replaced the exhaust pipe they rounded both of the nuts off. I went ahead & shot the nuts with some PB, then had some pizza for dinner. When I went out to the car & put a socket with a ratchet on the nuts all that happened was the socket spun on the nuts.:eek: I knew I was really screwed then, I shot some more PB on the nuts. Then I went to Sears to get a speciality socket set that was supposed to work on rounded bolts & nuts. I wasn't having any luck getting the nuts to break loose with the new sockets. I sprayed the nuts again with some more PB before calling it a night. Today I tried it once more but the new sockets weren't working. I tried heating the nuts up with a torch, & then trying to free the nuts with some vice grips; still no luck. Sorry for being so long with the explanation. But right now I have an absolutely rounded nut with a death grip on the down pipe stud, I haven't done anything else with the other nut after the first attempt. I'm thinking that my only option right now is to cut the studs so I can get the down pipe off so I can replace the turbocharger. If anyone has another suggestion I would like to hear it. If I have to cut the studs on the down pipe, then I'll need to replace this as well. Now if I order a stock pipe then the BNR, & the software tuning will work fine with this set up (as I understand). But if I were to order an aftermarket pipe such as some that I've read about here (Cobb, Infamous, ect) will this have any adverse effect with the BNR 16G turbo, & the software tuning? Link to comment Share on other sites More sharing options...
hadvw Posted February 14, 2011 Share Posted February 14, 2011 AFAIK, the tuning should work either way (although you might have to adjust for a different flow rate on an aftermarket cat, or no cat, as the case may be). If you don't mind spending the $$$, you could go aftermarket, and your tuner should be able to adjust. On the other hand, if you prefer to save some $$, find a used stock downpipe on the for-sale lists here. Shouldn't be too hard, since you only need the top part, and you can probably get one for around $50-70 shipped. Just be aware that there is a difference between manual and automatic downpipes, so make sure you get the right one for your model! Link to comment Share on other sites More sharing options...
