adama Posted February 10, 2011 Share Posted February 10, 2011 hey all sorry if this is in the wrong spot im new here. so i have a 96 Subaru legacy it will start cold and run fine but when i turn it off it loses spark and i have to let it set for a few hours. i put in new spark plugs and wires, but the problem persists, read the obd2 and only found a code for o2 censors. tried to test the coil but i am getting weird numbers not even close to book specs, went to the junk yard and got the same reading, so i think im just doing it wrong idk. any ideas what would cause this assuming its not the coil? and should i even be assuming that? i would greatly appreciate your expertise. Link to comment Share on other sites More sharing options...
GTTuner Posted February 10, 2011 Share Posted February 10, 2011 See if you get a pulse from the negative side of the coil when it won't start, use a common 12v test light. Link to comment Share on other sites More sharing options...
adama Posted February 11, 2011 Author Share Posted February 11, 2011 so i used a light and there are three wires running into the coil, when i turned the key on all three of them got power, and the car is starting, i will retest when the car does not start, is this normal though? Link to comment Share on other sites More sharing options...
adama Posted February 11, 2011 Author Share Posted February 11, 2011 so when the car could not start none of them got power Link to comment Share on other sites More sharing options...
GTTuner Posted February 11, 2011 Share Posted February 11, 2011 Possibly a bad igniter. Link to comment Share on other sites More sharing options...
adama Posted February 11, 2011 Author Share Posted February 11, 2011 went to the junk yard, got another igniter and no change. maybe i got a bad one, is there a way to test Link to comment Share on other sites More sharing options...
subikid90 Posted February 11, 2011 Share Posted February 11, 2011 Possibly the wiring harness before the igniter is bad or worn? -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
GTTuner Posted February 11, 2011 Share Posted February 11, 2011 You need a wiring schematic, you are loosing a power feed from somewhere. Link to comment Share on other sites More sharing options...
