GT_Red Posted February 10, 2011 Share Posted February 10, 2011 Ok I searched and searched and couldn't find anything on actually replacing or swapping out the e-brake handle. Is this something you just pull off, heat up and pull off or cut off? The bottom leather piece has come off and I am not interested in gluing it back on, just replace it. THanks! Link to comment Share on other sites More sharing options...
roll_tide Posted March 15, 2011 Share Posted March 15, 2011 I have an 08... not quite sure what you have. For mine at least, its actually pretty easy to pull. If you start at the front edge and pull upwards (possibly even pry with some sort of plastic pick) youll find 3 black tabs towards the passenger side of the e-brake. There are two more tabs on the bottom, pointing downward. As to replacing, no idea. Stock would be my guess. Im looking to replace mine as well Link to comment Share on other sites More sharing options...
Mark34 Posted March 24, 2011 Share Posted March 24, 2011 Are you talking about the actual handle or the boot? If it's just the boot, I would get a replacement from Maciek @ Redline Goods. He does excellent work and can make whatever you want. He also just started releaseing e-brake handle covers. The boots are glued on to a plastic panel like roll_tide stated. Then you can use some heat to soften the adhesive, pull off the old one, and glue the new one on. As for the actual handle, I had to cut mine off with a Dremel. Went with a JDM Momo one. I've only seen one other thread before talking about it and that guy had to cut the stock one off too. So, if you definitely want to go with the replacement handle idea, you better be commited because once you start the removal process you can't go back. Link to comment Share on other sites More sharing options...
Phila Posted May 31, 2012 Share Posted May 31, 2012 If you are replacing the stock plastic e-brake lever with the OEM (from same model year) leather e-brake lever, it will bolt up all the same, or am I missing something? Link to comment Share on other sites More sharing options...
