carguyco Posted February 10, 2011 Share Posted February 10, 2011 I am wondering if you guys can help with something... Today I noticed a funny noise and I will try my best to explain what I'm hearing... This noise happens in gear/out of gear and movinghttp://script.clickbubbles.net/res/img/icons/underlined.png?1/not moving...so that narrows it down to engine areahttp://script.clickbubbles.net/res/img/icons/underlined.png?1.... At idle....800ish RPM...nothing.... When engine speed hits 2400-2500 there is a low humming/growling/ noise...in any gear, including neutral at a stop. I had my wife do the throttle while I listened with the hood open....the noise sounds like its coming from the intercooler area. The noise is loud enough that I started to notice the annoyance today so it is recent. Performance seems fine..... It sounds almost like a bearing of some sort that is howling.... Again, in gear out of gear, moving or at a stop......doesn't matter, noise is the same. Is my turbo starving for oil and about to die? Thanks in advance. Link to comment Share on other sites More sharing options...
ouch1011 Posted February 10, 2011 Share Posted February 10, 2011 Engine load won't be high enough in neutral to get the turbo to spin very fast (by turbo standards). I'd say it is more likely to be trans/clutch related. The clutch sits directly below the intercooler. Does the sound change with the clutch in/out? Link to comment Share on other sites More sharing options...
carguyco Posted February 10, 2011 Author Share Posted February 10, 2011 Nope, clutch in / out does not change the noise. Today I will remove engine cover and listen...may make it easier to hear. Link to comment Share on other sites More sharing options...
GTTuner Posted February 10, 2011 Share Posted February 10, 2011 I had my idler pulley for the AC belt fail and it made a similar noise. Grinding that changes with engine RPM. Link to comment Share on other sites More sharing options...
carguyco Posted February 11, 2011 Author Share Posted February 11, 2011 Mine is weird......it literally quits completely when it slows down after revving to 2k in rpm.....weird. I haven't taken the engine cover off yet, will do so in a bit. It sounds like a monk saying OOOOHHHHHHMMMMM..only a tiny bit higher pitched. I will try to record it when I take the cover off. Link to comment Share on other sites More sharing options...
Mega Users LieutenantDan Posted February 11, 2011 Mega Users Share Posted February 11, 2011 My timing belt tensioner went bad once and made a sort of humming sound. You might could look into that. Grab a stethoscope or a long screwdriver to help pinpoint the sound Link to comment Share on other sites More sharing options...
carguyco Posted March 19, 2011 Author Share Posted March 19, 2011 Had an oil change due today and since last oil change was when this sorta started...i asked them to look at it. As it turns out, the AC belt wasn't on properly which they had taken off when they replaced the serpentine belt last visit. All is now well....just in case someone else has this problem i thought I would post what happened. Link to comment Share on other sites More sharing options...
