oyway Posted February 6, 2011 Share Posted February 6, 2011 Hello I have error code 24 (Air control valve) in my 1992 Subaru Legacy 2.0 Turbo. The Check Engine lamp goes on when i'm going down in gear (using the engine to brake) around 2000-3000 RPM and turns off when I press the clutch for few seconds. Sometimes when I press the clutch the engine turns off. As well, When the lamp in on the performance are bad. What should I do? Where this valve is? Thank you very much, Sorry about my lousy English. Regards, Daniel. Link to comment Share on other sites More sharing options...
