Zac88 Posted January 28, 2011 Share Posted January 28, 2011 Looking to replace my stock struts with Bilstein HDs. Reasoning is that I want a stiffer ride but I cant lower my car so I have to use stock springs. So can I just buy the struts or do I need to buy different springs with SpecB tophats? Link to comment Share on other sites More sharing options...
goneskiian Posted January 28, 2011 Share Posted January 28, 2011 I think you may need springs to match. If you went with the Koni struts you wouldn't need anything else except maybe a set of donor front struts if you don't want to cut yours open. If they're the originals though, they're pretty much ready for the scrap heap anyway. It's really a pretty easy install if you have a tape measure, drill and hacksaw. Cheers! Link to comment Share on other sites More sharing options...
KartRacerBoy Posted January 28, 2011 Share Posted January 28, 2011 This site has a search function and this subject has been discussed to death in the suspension section. Link to comment Share on other sites More sharing options...
GTLEGACY007 Posted January 29, 2011 Share Posted January 29, 2011 I'm running Bilstein HDs on Rallitek Springs with Spec B tophats with a spacer in the rear. These springs lower the car about 1/4"-1/2", not even noticable to the eye, really. They ride just like stock, but handle much better. This is definitely the way to go if you don't want to lower the car. If I were you i'd look for a set of used HDs that include the Spec B tophats and pick up some Rallitek springs as well. Put those on the fronts, and reuse your stock rear tophats. Throw a 3/8" spacer on the back and the ride height front and rear will be even. Then enjoy. Will look like this: http://i208.photobucket.com/albums/bb223/0honegt/Legacy/IMAG0249.jpg http://i208.photobucket.com/albums/bb223/0honegt/Legacy/IMAG0222.jpg Link to comment Share on other sites More sharing options...
mr.hicksta Posted January 29, 2011 Share Posted January 29, 2011 I'm running Bilstein HDs on Rallitek Springs with Spec B tophats with a spacer in the rear. These springs lower the car about 1/4"-1/2", not even noticable to the eye, really. They ride just like stock, but handle much better. This is definitely the way to go if you don't want to lower the car. GTLEGACY007 is right on.....very conservative drop with that combo. I believe those are my old Ralliteks too :-). I've got Bilsteins/Swifts with 3/8 spacer and it's about the same as the Bilstein/Rallitek combo. Your ride's looking nice man!!! Link to comment Share on other sites More sharing options...
Zac88 Posted January 29, 2011 Author Share Posted January 29, 2011 so just to make this clear I NEED SpecB Tophats for Bilstein HDs? And my stock springs WONT work? Link to comment Share on other sites More sharing options...
