dride24 Posted January 27, 2011 Share Posted January 27, 2011 On several occasions, I have drained my battery by leaving a map light (overhead up by the sun visors) on. I wonder whether anyone has been able to wire these into an available ignition controlled power source like the autodimming mirror or the vanity mirror light on the visor. Link to comment Share on other sites More sharing options...
AkumaMax Posted January 28, 2011 Share Posted January 28, 2011 you could do that. Just run a (+) wire to the lights and run it to the ignition or accesory spots under your dash. You must cut the constant power from the lights first. The problem with this is that they will be useless without power unless wired into a relay and switch. Link to comment Share on other sites More sharing options...
David E Posted January 29, 2011 Share Posted January 29, 2011 If you have a sunroof the power is only on to it when the ignition is on. Link to comment Share on other sites More sharing options...
BAC5.2 Posted January 29, 2011 Share Posted January 29, 2011 If you have a sunroof the power is only on to it when the ignition is on. No it's not. I can turn my maplights on anytime I want. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
Drift Motion Posted January 29, 2011 Share Posted January 29, 2011 No it's not. I can turn my maplights on anytime I want. he's giving out an idea on where to tap the power instead Link to comment Share on other sites More sharing options...
David E Posted January 30, 2011 Share Posted January 30, 2011 That's right. Just finished today tapping the sunroof wires to power an autodimming mirror for my SVX. Link to comment Share on other sites More sharing options...
