Truspeed Performance Posted January 22, 2011 Share Posted January 22, 2011 Trying to find cam profiles and a few other little things I still need for burns stainless to give me their recommendations on headers for this car. We are doing a full header back exhaust for a 1996 legacy L that would be the one with the EJ22. I have all other specs besides the following. If anyone can help that would be AWESOME! -Intake valve head diameter -Exhaust valve head dia. -Cam manufacturer & model # -Intake lift at valve -Int. duration @ .050 lift ___ degrees -Exhaust lift at valve -Exh. duration @ .050 lift ___ degrees -Cylinder head model -Intake port dimensions -Exhaust port dimensions -Lifter type (roller, flat, hyd.) -Intake rocker arm ratio -Intake lobe centerline -Exhaust rocker arm ratio -Exhaust lobe centerline Link to comment Share on other sites More sharing options...
