poonhandler Posted January 19, 2011 Share Posted January 19, 2011 Does the 90 -94 legacy turbo have the same front brake set up as a 90 legacy ls? Found some powerslot rotors for a turbo and was wondering if it would bolt up to my ls? Are the backing plates and calipers a different size? Any help would be great Link to comment Share on other sites More sharing options...
poonhandler Posted January 21, 2011 Author Share Posted January 21, 2011 No one? Link to comment Share on other sites More sharing options...
sqc151 Posted January 21, 2011 Share Posted January 21, 2011 turbo SS was only made between 91-94. brakes should fit if you use the turbo mounting bracket/caliper. Link to comment Share on other sites More sharing options...
poonhandler Posted January 24, 2011 Author Share Posted January 24, 2011 I've read the turbo uses 10.5 " front brakes and the ls runs 10.2". Any insight? Link to comment Share on other sites More sharing options...
91-Leggy_RX Posted January 24, 2011 Share Posted January 24, 2011 i used 03 wrx brakes. all i had to swap was the calipers, caliper mounts, and rotors. 2 pot > 1 pot stops very nicely now. Link to comment Share on other sites More sharing options...
