Bellmer Posted January 18, 2011 Share Posted January 18, 2011 Soo.. I bent a lateral link by accidentally hitting a curb:mad: and I am having the hardest time getting the 2 bolts out that hold it on is the a trick to it?? and is there a difference in impreza like these links its a 1997 legacy gt sedan. http://i419.photobucket.com/albums/pp280/jbellmer/cars/011.jpg http://i419.photobucket.com/albums/pp280/jbellmer/cars/001-1.jpg Bolt 1 http://i419.photobucket.com/albums/pp280/jbellmer/cars/003-1.jpg http://i419.photobucket.com/albums/pp280/jbellmer/cars/004.jpg and 2 http://i419.photobucket.com/albums/pp280/jbellmer/cars/005.jpg Link to comment Share on other sites More sharing options...
subikid90 Posted January 18, 2011 Share Posted January 18, 2011 From bending it you probably have a ton of tension on it. If you can take a cut off wheel to the bar and cut it to release the tension. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
johnegg Posted January 18, 2011 Share Posted January 18, 2011 those bolts are a b1tch even when they aren't bent, especially in the rust belt. use everything, pb blaster, breaker bars, long pipes, heat, hammers, and if necessary, a sawzall. although you may be past the sawzall stage since the nut is off. at some point you may want to take it to a shop and let them do the hard part. it's worth it to me sometimes just to get it over with. buy a replacement and take in and ask them to replace it. Link to comment Share on other sites More sharing options...
jamesm113 Posted January 18, 2011 Share Posted January 18, 2011 propane torch (heat till red hot) + long breaker bar worked out some pretty stuck bolts for me in the past Link to comment Share on other sites More sharing options...
kushmastercain Posted January 18, 2011 Share Posted January 18, 2011 brute force!! Link to comment Share on other sites More sharing options...
kushmastercain Posted January 18, 2011 Share Posted January 18, 2011 mine came right out i used an air ratchet Link to comment Share on other sites More sharing options...
Bellmer Posted January 19, 2011 Author Share Posted January 19, 2011 Will the same year imprezza links work? The looks yhe same.. Link to comment Share on other sites More sharing options...
kushmastercain Posted January 19, 2011 Share Posted January 19, 2011 Idk about that year but 04 impreza Sti suspensionparts work that's what I'm doing Link to comment Share on other sites More sharing options...
Bellmer Posted January 19, 2011 Author Share Posted January 19, 2011 ok thanks! Link to comment Share on other sites More sharing options...
