RiceViper Posted January 17, 2011 Share Posted January 17, 2011 OK, I have an 06 lgt w/ 66k. Under hard acceleration there is a grinding coming from trans area. Im a service writer but unfortunatlly i work for a chevrolet store. I just flushed the trans out and now Ive been told to probably lean towards the front diff. Im not looking for a thousand it might bes but would love if any one has and dianostic tips to help me track this down. Noise only happens when accelrating very hard and will not go away until I let off the throttle. Thank you!! Link to comment Share on other sites More sharing options...
Vinny78 Posted January 17, 2011 Share Posted January 17, 2011 check your dif oil located on the passenger side of engine towards back , looks like a trans dip stick but its ur dif. If level is good and fluid looks good its gotta be in trans, . Could be the cluctches in the trans they get stuck together and grind, taking a hard corner while accelerating will break them loose. sounds wacky cause its an automatic but auto trans have clutches to as u prob no! i work at a Subaru dealer and sometimes that happens. keep me updated il try and talk to people at work and get the prob solved Link to comment Share on other sites More sharing options...
RiceViper Posted January 17, 2011 Author Share Posted January 17, 2011 Ill check the diff fluid in the morn. I flushed the trans as the clutches have been known to stick and cause this grinding. Was told the flush could take a few miles of drivin to work it out so ill see how it works, no difference as of now though. Thank u and ill be in touch Link to comment Share on other sites More sharing options...
Vinny78 Posted January 17, 2011 Share Posted January 17, 2011 not a prob what we do at work is take hard corners and it usually breakes them loose if not u may need to take trans apart Link to comment Share on other sites More sharing options...
RiceViper Posted January 17, 2011 Author Share Posted January 17, 2011 Hard sharp corners??? Will this be somthing that just pops loose and ill be able to tell or is it more of a gradual thing Link to comment Share on other sites More sharing options...
Vinny78 Posted January 17, 2011 Share Posted January 17, 2011 yes it will break the clutches loose after a few sharp corners it doesnt work then the tranny will have to come apart but most of the time it works if it is the clutches sticking together. when i say hard cornering i mean like completley turn the wheel all the way to the right or left and accelerate in a circle. find an open parking lot Link to comment Share on other sites More sharing options...
Vinny78 Posted January 17, 2011 Share Posted January 17, 2011 also make sure your axles are ok a cracked axle boot will cause all grease to leak out and cause a noise Link to comment Share on other sites More sharing options...
RiceViper Posted January 19, 2011 Author Share Posted January 19, 2011 The noise appears to be coming from the bearing in the front of the rear diff. and it is resonating foward. 5 mins with a subie tech and his diag is done. Cam shaft seals are leaking as well Link to comment Share on other sites More sharing options...
blongo804 Posted January 20, 2011 Share Posted January 20, 2011 I have that exact sound you described RiceViper. Mine must be the same problem. Â Excuse my ignorance to this diagnosis, but this was a 5 minute fix or just took 5 minutes to figure this out? If it was 5 minutes to figure out, how much to fix? Link to comment Share on other sites More sharing options...
RiceViper Posted January 20, 2011 Author Share Posted January 20, 2011 Took 5 mins to figure out, breaking the diff down today to figure out a total cost. Labor guide only calls for 2.8hrs to overhaul a rear diff, plus parts. Depending on ur labor rate anywhere from 350.00 to 180.00. Easy to find the prob out with a stethescope when the car is on a lift and wheels spinnin. Ill keep u posted. Thanks for all the help so far guys. Anyone have a plug recomendation...i dont wanna change em all the time, just didnt know if there was somthing else out there then a stock plug. Im just runnin a tune and a k+n with the silencer removed. Link to comment Share on other sites More sharing options...
ehsnils Posted January 20, 2011 Share Posted January 20, 2011 As for spark plugs - go for NGK, and if you have a mod+tune you may consider one step colder plugs. ILFR6B or ILFR6T-11 are the recommended plugs from what I can determine at the NGK site. They are slightly different but both fits (same connector and threading) and will do it's job. However if you do more mods I think that the ILFR6B is the better alternative. And if the gap is wrong it's a simple thing to adjust. ILFR6B (For the EJ257 found in the STi) Extreme Long Life Laser Iridium Plug, 14mm Thread Size, 26.5mm (1.04") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Projected Tip, Solid Terminal Nut, Iridium Tipped Fine Wire Center Electrode with Platinum Tipped Tapered Cut Ground Electrode, .031" (0.8mm) Gap, Heat Range 6 ILFR6T-11 (For the EJ255 found in many others) Extreme Long Life Laser Iridium Plug, 14mm Thread Size, 26.5mm (1.04") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal Nut, Iridium Tipped Fine Wire Center Electrode with Platinum Tipped Tapered Cut Ground Electrode, .043" (1.1mm) Gap, Heat Range 6 Beware if you get this one since the thread length is shorter than the thread in the cylinder head: BKR5EIX-11 (For the 2.5i) Iridium IX Plug, 14mm Thread Size, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal Nut, ISO Length, Projected Tip, Fine Wire (0.6mm) Iridium Center Electrode, Tapered Cut Ground Electrode, .043" (1.1mm) Gap, Heat Range 5 Link to comment Share on other sites More sharing options...
RiceViper Posted January 21, 2011 Author Share Posted January 21, 2011 New subie diff, t-belt + tensioner, cam shaft seals. All will be completed next week Link to comment Share on other sites More sharing options...
RiceViper Posted January 28, 2011 Author Share Posted January 28, 2011 diff fixed the vibration!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
blongo804 Posted January 28, 2011 Share Posted January 28, 2011 Thank goodness! That's good to hear for you, but unfortunatly for me, I have no warranty and would have to pay straight up for a new Diff.. How much do these run? Too much for me? Yes lol. Link to comment Share on other sites More sharing options...
RiceViper Posted January 31, 2011 Author Share Posted January 31, 2011 List for the diff is about 750 and it calls for about 2 hrs to swap em. But please make sure u isolate the problem, ide hate to see u swap diff if its not the prob. Link to comment Share on other sites More sharing options...
