TRSCobra Posted January 17, 2011 Share Posted January 17, 2011 I'm hearing (on Nasioc) that I might be running out of injector with my current 20G setup, but I maxed out at 84% IDC. Anyway, here's a 3rd gear log I took today... Thanks.datalog2.csv Link to comment Share on other sites More sharing options...
rtbrjason Posted January 17, 2011 Share Posted January 17, 2011 If you just log the parameters I left on the sheet pictured,(also knock sum and maybe turbo dynamics integral) you would have a lot more than 16 lines of useful data. Those 16 lines of data however appear fine. You should also start your pull at 2k and go to redline if possible. Link to comment Share on other sites More sharing options...
TRSCobra Posted January 17, 2011 Author Share Posted January 17, 2011 If you just log the parameters I left on the sheet pictured,(also knock sum and maybe turbo dynamics integral) you would have a lot more than 16 lines of useful data. Those 16 lines of data however appear fine. You should also start your pull at 2k and go to redline if possible. Thanks. I'm pretty new when it comes to logging, and I started a bit late in the run. Link to comment Share on other sites More sharing options...
TRSCobra Posted January 17, 2011 Author Share Posted January 17, 2011 Here's a better one if anyone's interested. From second through third gear, IDC hit 85% this time.datalog3.csv Link to comment Share on other sites More sharing options...
