TheAsian Posted January 16, 2011 Share Posted January 16, 2011 Ok here's the deal, bought a 98 legacy gt 4eat with popped head gaskets. My question is the car has the engine out and the battery out. Trying to put it in neutral to move it into the shop to put the engine back in, the front axles won't disengage. I've read rumors online that with no power it won't release the parking lock. It dose feel like the shift cable is still connected. Thanks for the help Link to comment Share on other sites More sharing options...
johnegg Posted January 16, 2011 Share Posted January 16, 2011 on the front edge of the shifter indicator there is a small square and / or hole. insert a screw driver and you can release the shift lock allowing you to move the shifter in to ''N''. Link to comment Share on other sites More sharing options...
TheAsian Posted January 16, 2011 Author Share Posted January 16, 2011 Maybe I wasn't clear, I can move the gear selector to neutral fine and when in neutral the front axles won't disengage. Link to comment Share on other sites More sharing options...
johnegg Posted January 17, 2011 Share Posted January 17, 2011 you got me. hand brake on?? the trans park lock is purely mechanical. shift into park and a hook / pawl engages the gear on the rear of the trans preventing it from turning. it is not electronic. there is an electronic solenoid to release the shifter though. Link to comment Share on other sites More sharing options...
camroncamera Posted January 17, 2011 Share Posted January 17, 2011 I started my headgasket project on my '98 LGT 4EAT by leaving the key in the ignition with the shift lever in N. After the engine was removed, the car took a lot of force to roll it on a flat concrete surface, I would say more effort than with a comparably sized 5-speed vehicle in neutral. Make sure you haven't forgotten to remove any wheel chocks hiding behind your tires Link to comment Share on other sites More sharing options...
TheAsian Posted January 17, 2011 Author Share Posted January 17, 2011 Thanks, Yea no tire chalks or anything. Ive been using our tractor to move it around. Thanks camron Im just going to install the engine and see how it goes. Link to comment Share on other sites More sharing options...
KuNomn Posted January 17, 2011 Share Posted January 17, 2011 I started my headgasket project on my '98 LGT 4EAT by leaving the key in the ignition with the shift lever in N. After the engine was removed, the car took a lot of force to roll it on a flat concrete surface, I would say more effort than with a comparably sized 5-speed vehicle in neutral. Make sure you haven't forgotten to remove any wheel chocks hiding behind your tires same here. After finishing my engine build it was time to move the car back to the front of the garage for install. I had to use 2 friends pushing and a twin cam sable pulling just to move the car. Link to comment Share on other sites More sharing options...
TheAsian Posted January 17, 2011 Author Share Posted January 17, 2011 cool thanks again guys. Link to comment Share on other sites More sharing options...
