!!WRX/Evo Challenge Event Calendar!!
Saul_Good
Legacies can enter too!!
Here's the link to the actual WRX/EVO challenge events put on by Speedventures. Prizes and trophies to be had!!
http://svc.speedventures.com/fly.aspx?layout=events&series=24
See you out there.
Here are the classes and their requirements:
Street Class
0 to <=6 points
Modified Class
6> to <=13 points
Unlimited Class
13> points
AERO
0.50 = front splitter
0.25 = aftermarket rear diffuser
1.25 = aftermarket wing
TIRE / WHEEL
Compound:
0.75 = level 1 street tires (RT615, RS2, MX, CSC3, PS2)
1.50 = level 2 street tires (Z1, AD07/8, RE01R, R1R, 595RSR, NT05, RE070)
3.50 = R-comp (RA1, R888, NT01, A048, PSC) / not allowed for street class
4.00 = C91, A6, V710, non-DOT, and all un-named <100 treadwear tires / unlimited class only
Size:
0.25 = 265
0.50 = 275
1.00 = 285s or bigger
ENGINE
0.25 = aftermarket header
0.75 = test pipe / downpipe
0.25 = cat-back exhaust
0.75 = aftermarket stand alone ECU
1.50 = engine swaps (from different chassis)
1.00 = aftermarket camshaft/headwork
2.00 = aftermarket turbocharger OR
3.50 = aftermarket turbocharger with 4" (100mm) compressor housing
SUSPENSION / BRAKES
0.75 = swaybar upgrade
0.50 = drop springs and/or aftermarket shocks
2.00 = 1 way adjustable coilover suspension
2.50 = 2 way adjustable coilover suspension
3.50 = 3+ way adjustable coilover suspension
1.50 = aftermarket brake kit (non-oe caliper upgrades)
DRIVETRAIN
0.50 = transmission swap (from different chassis)
WEIGHT REDUCTION
0.00 = Lightweight hood
0.25 = Lightweight trunk
0.25 = Lightweight front fenders
0.50 = Lightweight front doors
0.50 = Lightweight rear doors
0.50 = Lightweight roof
0.25 = Front door reinforcement / electric window motor removal
0.25 = Rear door reinforcement / electric window motor removal
0.25 = Lightweight glass (0.25 points per glass)
0.50 = AC system and/or heater core removal
0.25 = passenger seat removal
0.00 = rear seat removal
- For street class, weight reduction limited to battery, spare tire, tools, light weight body panels, bucket seats, passenger and rear seat removal.
- Modified class must retain windshield & rear glass.
- Unlimited class must have rollcage IF lightweight doors installed, door reinforcement / electric window motor are removed.
SAFETY bonus
-0.25 = neck support (Hans or similar, excluding donut style)
-0.25 = roll bar installation
-0.50 = full roll cage installation
