SebGT98 Posted January 14, 2011 Share Posted January 14, 2011 Flat spot from 3200rpm to about 4100, when I am taking off I get to about 3200rpm's and it feels like it is bogging and hesitating all the way through to around 4 like I was saying. Once its past 4000 it takes off normal, feels like a little boost once its through that spot. Its a complete power loss in first gear when I'm trying to take off quick, really want to figure this one out, hopefully you guys can help, thanks. Link to comment Share on other sites More sharing options...
carnumber19 Posted January 14, 2011 Share Posted January 14, 2011 Is the flat spot there in all the gears, and when you rev it up in neutral does it seem to slow down its rate of increase while it goes through that spot? Link to comment Share on other sites More sharing options...
SebGT98 Posted January 14, 2011 Author Share Posted January 14, 2011 Yes it is in all the gears but when I bring it up to 6000 rpm's the guage doesnt drop back down to 3000 so its really only noticable in the first gear I'm taking off in, whether it be from a stop, or 2nd gear pull or whatever. Unless of course I shift earlier and it goes below 4000, then it will hesitate. I can't remember whether or not it does it in neutral but I will deffinitly try it today and let you know. Thanks. Link to comment Share on other sites More sharing options...
