ejc2g Posted January 14, 2011 Share Posted January 14, 2011 before anyone bashes me, I have spent the last 2-3 hours searching through the forums looking for an answer that I can't find. I have a vag-com cable, installed the ftd drivers, changed the baud to 4800, updated .net and everything I was suppose to do. When I try to connect with learning view, its comes up with an "error": ECU ID ********** not found in definitions. What am I doing wrong? I am trying to obtain the Rom ID to have Infamous tune it. Please help! Thanks Link to comment Share on other sites More sharing options...
ejc2g Posted January 14, 2011 Author Share Posted January 14, 2011 I'm really thinking its something to do with the Vag-com cable itself, I might just have to give in a buy the Tactrix. Link to comment Share on other sites More sharing options...
almostinvincible119 Posted January 14, 2011 Share Posted January 14, 2011 I have a vagcom cable I bought from Infamous and it doesn't work flashing the ecu with ECUFlash. I have an ebay cable coming that hopefully works. If not, I'm gonna have to find a tactrix 2.0 Link to comment Share on other sites More sharing options...
iNVAR Posted January 14, 2011 Share Posted January 14, 2011 That's actually what it says? ECU ID **********? With the *s? Or you blanked it out to post here? What year/make/model of car? The vagcom cable I have works perfectly with ECUFlash, LV and RR. Link to comment Share on other sites More sharing options...
ejc2g Posted January 14, 2011 Author Share Posted January 14, 2011 the asterisks where just the ECU ID numbers, i didnt remember them, so I just used that instead, sorry for the confusion. the car is an 05 5EAT. I've tried it with all the programs and it doesn't work with any of them. Link to comment Share on other sites More sharing options...
iNVAR Posted January 14, 2011 Share Posted January 14, 2011 What OS is your laptop? Which version of the FTD drivers did you use? Link to comment Share on other sites More sharing options...
ejc2g Posted January 14, 2011 Author Share Posted January 14, 2011 I tried it on Windows 7 and on XP, same problems on both. Tried both versions of the FTD driver. Link to comment Share on other sites More sharing options...
iNVAR Posted January 14, 2011 Share Posted January 14, 2011 By version, I mean do you have a link? Or a version number? And is it 64 bit or 32 bit Windows? Link to comment Share on other sites More sharing options...
iNVAR Posted January 14, 2011 Share Posted January 14, 2011 I found this. My search skills are superior to yours. I used google. http://legacygt.com/forums/showthread.php/unknown-ecu-id-after-uninstalling-accessporti-116719.html Your problem isn't an issue with the cable or drivers.... since it's reading the ECU ID just fine. Do you have the latest version of LV? Also, post the ECU ID version here. Link to comment Share on other sites More sharing options...
iNVAR Posted January 14, 2011 Share Posted January 14, 2011 http://www.romraider.com/forum/topic2772.html Supported ECUs: Learning View supports 260 different Subaru ECU revisions including those listed HERE (except for NA ROMs E2ZD508C, E2ZD308E, E2VG212E, and E2TB101Q). In addition, some additional ECUs were added in the last release (0.4a) that are not listed, based on user submissions up to that point in October of 2008. http://www.romraider.com/Documentation/SupportedECUs Legacy 2.5i 05 E2ZJ101B# (MT/AT)*, E2ZJ141B# (MT/AT)*, E2ZJ173B# (MT/AT)* 06 E2VG221B# (MT/AT)* 08 EZ1D105C (MT)*, EZ1D201D (AT)* 09 EZ1D302B (AT)*, EZ1D302C (MT)*, EZ1D302D (AT)* Legacy GT 05 A2WC500C (AT)*, A2WC500N (MT)*, A2WC510C (AT)*, A2WC510N (MT)*, A2WC511C (AT)*, A2WC511N (MT)*, A2WC521C (AT)*, A2WC521N (MT)*, A2WC522N (MT)* 06 A2WF200C (AT)*, A2WF200N (MT)* 07 A2UG000C (AT)*, A2UG000N (MT)*, A2UI001C (AT)* 08 A2TB000N (MT)* Link to comment Share on other sites More sharing options...
m sprank Posted January 16, 2011 Share Posted January 16, 2011 I have a vagcom cable I bought from Infamous and it doesn't work flashing the ecu with ECUFlash. I have an ebay cable coming that hopefully works. If not, I'm gonna have to find a tactrix 2.0 You have posted at least twice that your cable is not working. What is the issue? Link to comment Share on other sites More sharing options...
