joedirtae09 Posted January 13, 2011 Share Posted January 13, 2011 Ive noticed that some of you guys have catless downpipes, how do you pass the emmisions tests in VA? Im lookin to buy a downpipe and the price difference is petty big between catted and catless. Do you guys go to a certain gas station? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted January 16, 2011 I Donated Share Posted January 16, 2011 Does Virginia do a sniffer test, or just an OBDII test? If it's just an OBDII test, just get an Accessport or Tactrix cable and delete the P0420 DTC code and you'll be golden. Link to comment Share on other sites More sharing options...
compsurge Posted January 16, 2011 Share Posted January 16, 2011 And to get rid of the nasty catless smell, get a catted CNT downpipe from one of the many group buys on this forum (something like $285 shipped). No reason not to! Link to comment Share on other sites More sharing options...
SubieChik Posted January 17, 2011 Share Posted January 17, 2011 Does Virginia do a sniffer test, or just an OBDII test? If it's just an OBDII test, just get an Accessport or Tactrix cable and delete the P0420 DTC code and you'll be golden. NOVA is the only place in VA that does the sniffer. Down here we just get the visual....and if you stumble upon the right place the inspector sees two cats if you get what I mean Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted January 17, 2011 I Donated Share Posted January 17, 2011 You guys have visual too???? Remind me to never move to Virginia! Link to comment Share on other sites More sharing options...
scoobydoobie Posted January 17, 2011 Share Posted January 17, 2011 You guys have visual too???? Remind me to never move to Virginia! Only a visual unless you are in NOVA. I've been passing no problems with a single highflow cat on my last two subies for 6+ years. They look to see that there's a cat and that's it.. My buddy with a catless STI simply tack welded a heat shield on his DP. Looks like a cat . Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted January 17, 2011 I Donated Share Posted January 17, 2011 Yeah, but Maryland only has an OBDII test. They plug in a code reader; if you have no codes and all your monitors are ready, you pass. Link to comment Share on other sites More sharing options...
compsurge Posted January 18, 2011 Share Posted January 18, 2011 In St. Mary's county MD, there are no emissions or OBD scans. Just the first safety inspection when buying the car, then pay them money for registration when due. Link to comment Share on other sites More sharing options...
joedirtae09 Posted January 20, 2011 Author Share Posted January 20, 2011 Only a visual unless you are in NOVA. I've been passing no problems with a single highflow cat on my last two subies for 6+ years. They look to see that there's a cat and that's it.. My buddy with a catless STI simply tack welded a heat shield on his DP. Looks like a cat . DAMN...... I live in NOVA. Can anyone recomend a shop to go to?? Im not above slipping a $20 to pass!! Link to comment Share on other sites More sharing options...
morrisco Posted February 25, 2011 Share Posted February 25, 2011 Well, I guess I'm in trouble. I recently moved to Stafford County and it seems like I'm going to have to get the e-test. I've always had my car registered and inspected in WV, where if they check the tread on your tires it's considered a tough inspection. My car is heavily modded with no cats. Is it worth going to a nearby garage and seeing if they will give me an "offline" e-test? I mean, they can't really report my car if it's not registered here, right? Ugh!!! I need to figure out a way to keep getting inspections in WV and keep my car registered there. If I can't go this route, can anyone recommend a good hi-flow cat and tuner in the NoVA area? Thanks all!! Link to comment Share on other sites More sharing options...
700watts Posted March 4, 2011 Share Posted March 4, 2011 I go to MD, I gots friends in good spots Link to comment Share on other sites More sharing options...
BAC5.2 Posted March 4, 2011 Share Posted March 4, 2011 Yeah, but Maryland only has an OBDII test. They plug in a code reader; if you have no codes and all your monitors are ready, you pass. They are SUPPOSED to do more, though. They are SUPPOSED to do a visual, and they are SUPPOSED to do a gas cap pressure test. But they don't. I took my wifes car the other day and the guy walked around the car with the mirror, but never actually stuck it under the car. He looked in the gas flap, but never touched the cap, plugged the scanner in, and that was all. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
700watts Posted March 4, 2011 Share Posted March 4, 2011 I took my wifes car the other day and the guy walked around the car with the mirror, but never actually stuck it under the car. He looked in the gas flap, but never touched the cap, plugged the scanner in, and that was all. Sounds about right....thats what they did for me Do you not like that ? Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 4, 2011 I Donated Share Posted March 4, 2011 The gas cap test is now only for older cars. I specifically asked about that when I took my LGT in, because they had always done the gas cap test on my 92 Infiniti G20 (and on my 90 Legacy wagon before that, and on my brother's 92 Legacy sedan), but they didn't do the test on my LGT. I go to the Owings Mills VEIP and they have never even gone around with a mirror or squatted down, let alone popped my hood. And I've taken six cars there at this point, some multiple times. They have ripped out the treadmills for pre-OBDII cars too... Just an idle tailpipe test for that. They were ripping them out when my G20 was last due for emissions, so I got an automatic 2-year extension FTW! And if I keep the car long enough for it to fail in November 2011, I'll just string them along until I sell the car or register it as historic in August 2012... Link to comment Share on other sites More sharing options...
SubieChik Posted March 4, 2011 Share Posted March 4, 2011 I go to MD, I gots friends in good spots You go to MD to get a VA sticker? Link to comment Share on other sites More sharing options...
700watts Posted March 4, 2011 Share Posted March 4, 2011 I knew that would come up....both of my vehicles are registered under my LLC. The LLC is based in MD. Link to comment Share on other sites More sharing options...
joedirtae09 Posted March 4, 2011 Author Share Posted March 4, 2011 ^ uh..... that helps alot Link to comment Share on other sites More sharing options...
