Luckysmile Posted January 10, 2011 Share Posted January 10, 2011 So I don't know a whole lot about cars and have not been able to figure this one out after some online searching. I got the glove box itself out, but the cabin air filter is still inaccessible unless I remove the whole panel thing for the glove box. Apparently this design was redone in 2006 to make it somewhat easier, but this doesnt really help me. any suggestions? Link to comment Share on other sites More sharing options...
Blue Posted January 10, 2011 Share Posted January 10, 2011 I haven't found an easier way to do it. You've just got to take it all apart, starting with the center console/storage box/arm rest. Silly, right? Link to comment Share on other sites More sharing options...
bmx045 Posted January 10, 2011 Share Posted January 10, 2011 when you search, you get: http://legacygt.com/forums/showthread.php/2008-cabin-air-filter-replacment-help-93471.html?t=93471&highlight=cabin+filter+change Link to comment Share on other sites More sharing options...
-The Boss- Posted January 10, 2011 Share Posted January 10, 2011 http://legacygt.com/forums/showthread.php/06-cabin-air-filter-replacement-18263.html?t=18263&highlight=cabin+air+filter Link to comment Share on other sites More sharing options...
KartRacerBoy Posted January 10, 2011 Share Posted January 10, 2011 What a pita and moronic design by subaru. Changing a filter shouldn't be that hard. Link to comment Share on other sites More sharing options...
RuskiTrombone Posted January 10, 2011 Share Posted January 10, 2011 It's done this way so they can make more money at the stealership. Link to comment Share on other sites More sharing options...
bmx045 Posted January 10, 2011 Share Posted January 10, 2011 It's done this way so they can make more money at the stealership. LOL. right. Link to comment Share on other sites More sharing options...
KartRacerBoy Posted January 10, 2011 Share Posted January 10, 2011 No doubt. Kinda like changing the front turn signal bulbs. Link to comment Share on other sites More sharing options...
Luckysmile Posted January 11, 2011 Author Share Posted January 11, 2011 I haven't found an easier way to do it. You've just got to take it all apart, starting with the center console/storage box/arm rest. Silly, right? So I have to take the whole center console apart? Is there a trick to this or is it pretty basic to figure out? when you search, you get: http://legacygt.com/forums/showthread.php/2008-cabin-air-filter-replacment-help-93471.html?t=93471&highlight=cabin+filter+change Also, the 08 model has a newer design that makes it somewhat easier. So when you look on that thread you see the part where he says you "remove those 5 retarded screws". I don't have that section built into glove box area. So after I drop the glove box its just all one big piece of annoying plastic that wont come out. Link to comment Share on other sites More sharing options...
Mistertribal Posted January 12, 2011 Share Posted January 12, 2011 Apparently this design was redone in 2006 to make it somewhat easier, but this doesnt really help me. any suggestions? 2006 has the same design as the 2005...still a PITA! Link to comment Share on other sites More sharing options...
iam_immigrant Posted February 17, 2011 Share Posted February 17, 2011 If anyone can help. I have a '05 LGT without the cabin filter 'option' and I've seen/read the thread where you have to dismantle the centre console/dash to change it and some even took it upon themselves to 'mod' the glove box so that it would be easier in the future. I remember the 'mod' was that they would dremel out a chunk of the plastic and such where the filter tray would hit. My question is would it be possible to dremel that section without taking apart the entire center console/dash??? Has anyone ever tried that? thanks Link to comment Share on other sites More sharing options...
rng Posted February 17, 2011 Share Posted February 17, 2011 I don't see why it wouldn't work. Just be careful that you're only cutting through the plastic panel. I had thought about doing what you're describing just the other day, but I ended up doing the install through the opening under the windshield cowling method instead. Folded the filter a little to get it in, and unfolded it over the panel. Took <10 minutes. Link to comment Share on other sites More sharing options...
Leonardo Posted February 18, 2011 Share Posted February 18, 2011 Just do what I did and get someone parting out their totaled car ang get the glove box assembly without the door skin. Even if you gut, you'll have a huge hole where stuff can fall out which is covered by a cloth in the one with the retrofit. Just in case for those with the retrofit: [ame=http://www.youtube.com/watch?v=X0Mm--92aTw]YouTube - Changing Cabin Air Filter[/ame] Link to comment Share on other sites More sharing options...
iam_immigrant Posted February 19, 2011 Share Posted February 19, 2011 Just do what I did and get someone parting out their totaled car ang get the glove box assembly without the door skin. Even if you gut, you'll have a huge hole where stuff can fall out which is covered by a cloth in the one with the retrofit. Just in case for those with the retrofit: YouTube - Changing Cabin Air Filter Thanks, I'll have to search the scrap yards...have not seen too many LGT where I am. Are the 2.5i compatible...can anyone confirm? I'm assume everything is the same between the two. Link to comment Share on other sites More sharing options...
