Baddog Posted January 8, 2011 Share Posted January 8, 2011 So I went out today to tackle the job of replacing the Rear Differential Fluid on my 4EAT. Got the fill plug out without much effort. (SCORE!) Then I go to the drain plug. Well no luck. It wasn't a socket type plug?. So I used a 1/2"(?) drive ratchet and just stuck it in there (this is what I did on the fill plug as well) Tons of trying and using a rigged up breaker bar. It started to round out the corners of the square. http://i830.photobucket.com/albums/zz223/Baddog909/IMG00548-20110108-1414.jpg It didn't budge. So anyone got an idea for me? If I get it off I am going to get a replacement (new). Or I was going to get a siphon tool and open up the fill plug again and drain all the old fluid out. Good or bad idea? Should also mention that I did try using a torch and penetrating sprays. PB Blaster I think the previous owner or someone overtorqued the drain plug. Anyways just need help. Link to comment Share on other sites More sharing options...
KuNomn Posted January 9, 2011 Share Posted January 9, 2011 I hate plugs that they used, they always give me a difficult time. It sounds like the siphon idea is your best bet. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted January 9, 2011 Share Posted January 9, 2011 Lol, to break mine loose, I had to use an 18" breaker bar and then slipped a 5-foot-long metal pipe over that and fought with it. It's incredible how tight they get, lol. Link to comment Share on other sites More sharing options...
KuNomn Posted January 9, 2011 Share Posted January 9, 2011 Lol, to break mine loose, I had to use an 18" breaker bar and then slipped a 5-foot-long metal pipe over that and fought with it. It's incredible how tight they get, lol. Same here. I love my 5 foot pipe. Because of it I've gotten away with not having air tools for years. Link to comment Share on other sites More sharing options...
soloz2 Posted January 9, 2011 Share Posted January 9, 2011 I couldn't get mine loose on my 98 and paid someone to do it for me. I haven't tried my 06 yet Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
Baddog Posted January 9, 2011 Author Share Posted January 9, 2011 Yeah I got all the old stuff out (I think) and put in some royal purple 75-90. Link to comment Share on other sites More sharing options...
GHS Posted January 9, 2011 Share Posted January 9, 2011 I got mine loose using a jack. I put the socket wrench at about 4:00 and the jack under the end of the wrench and started jacking. It lifted the body of the car up about 3" before the bolt broke loose. This is a great way to loosen stubborn bolts under the car, as long as the bolts are parallel to the ground. Link to comment Share on other sites More sharing options...
johnegg Posted January 9, 2011 Share Posted January 9, 2011 can you get an electric impact wrench on it? http://www.harborfreight.com/1-2-half-inch-electric-impact-wrench-45252.html Link to comment Share on other sites More sharing options...
hippo325 Posted January 9, 2011 Share Posted January 9, 2011 Luckily, mine came out with the use of a 3 foot ratchet driver. P.B and a couple light whacks with a dead-blow hammer and a 1/2" socket extension. I then took the plug against the bench mount wire wheel, cause it was a bit rusty (Ohio fer ya!) which cleaned it up nicely. I put it back in with anti-seize. Grease the thread edges so the salt won't re-rust it. Synthetic in both manual trans and rear differential. Link to comment Share on other sites More sharing options...
carnumber19 Posted January 10, 2011 Share Posted January 10, 2011 Same here. I love my 5 foot pipe. Because of it I've gotten away with not having air tools for years. I'd imagine your girlfriend/wife does too Link to comment Share on other sites More sharing options...
KuNomn Posted January 10, 2011 Share Posted January 10, 2011 I'd imagine your girlfriend/wife does too giggity:dm: Link to comment Share on other sites More sharing options...
