Calypsooofast Posted January 4, 2011 Share Posted January 4, 2011 :cool:can somebody post a link THANKS!!!!!!! Link to comment Share on other sites More sharing options...
Mark34 Posted January 4, 2011 Share Posted January 4, 2011 http://legacygt.com/forums/showthread.php/spark-plug-install-instructions-12070.html but you're going to have mess with the air pump tube because it's in the way you can follow that from here... http://legacygt.com/forums/showthread.php/2007-2009-air-pump-delete-cel-codes-and-ecu-fix-140259.html?t=140259&highlight=air+pump+delete but all you really need to do is loosen the two spring clamps on each end and pull it out. I think there is also a support screw on it by the pump. Discussion on for 08s here... http://legacygt.com/forums/showthread.php/anyone-08-turbo-done-spark-plugsi-151730.html Link to comment Share on other sites More sharing options...
Calypsooofast Posted January 5, 2011 Author Share Posted January 5, 2011 thanks mark big help....dosent sound like fun:mad: Link to comment Share on other sites More sharing options...
amp0412 Posted January 5, 2011 Share Posted January 5, 2011 Its really not as bad as people make it out to be. Just make sure that you have: approx 6in 3/8in extension 3/8 inch universal joint (swivel) and obviously whatever other sockets and the correct spark plug socket to disassemble everything else. Link to comment Share on other sites More sharing options...
