IAG Performance Posted January 4, 2011 Share Posted January 4, 2011 http://www.iagperformance.com/images/forum/nasioc/service/image_01_800.jpg Just wanted to put together a quick special thread for our LGT Locals: About Us: IAG Performance is a complete performance & service center, able to take on the smallest or largest projects. At IAG, we are very familiar with the entire Subaru line of vehicles and you can feel comfortable knowing your STI, WRX, Forester XT, Legacy GT, or naturally aspirated Subaru is in good hands while work is performed. Our customers' satisfaction and comfort during service is our number one priority! We are not about inflated service tickets or one time visits... At IAG, we hope to build long-term relationships that last a lifetime! A quick shot of our showroom: http://www.iagperformance.com/images/forum/nasioc/service/image_02_800.jpg IAG Performance Subaru Scheduled Maintenance Services http://www.iagperformance.com/images/forum/nasioc/service/image_05_800.jpg 30,000 & 90,000 Mile Service - $399 -Oil change using your choice of Motul or Valvoline Synthetics -K&N or Purolator Pure One Oil Filter & new drain plug washer -Replace Transmission Fluid w/ Motul 75w90 (Motul Gear300, Extra-S, and other fluids available upon request) -Replace Differential Fluid w/ Motul 75w90 (WRX) or Motul PA 90 (STi) -Coolant flush and inspect cooling system, hoses and connections. Global coolant w/ 1 bottle of Motul MoCool -Air Filter Service (replace factory filter w/ K&N Drop-In, or clean & lubricate existing filter) -Flush & replace brake fluid w/ your choice of Ate SuperBlue or Motul DOT 5.1 -Inspect brake pads and rotors -Inspect brake lines and check operation of parking brake -Inspect Front & Rear axle boots and axle shaft joint portions -Inspect clutch operation -Inspect Steering & Suspension -Inspect tires & rotate -PCV Valve -Top-off all fluids -Replace fuel filter (vehicles vary) and inspect fuel system 60,000 Mile Service - $499 -All services performed in 30K Service -Change spark plugs http://www.iagperformance.com/images/forum/nasioc/service/image_04_800.jpg 105,000 Mile Service - $899 -Replace Timing belt -Replace water pump & water pump gasket -Replace thermostat & thermostat gasket -Flush coolant & inspect cooling system. Global coolant w/ 1 bottle of Red Line Water Wetter or Motul MoCool -Crank Seal -A/C & P/S Belts -Cam Seals -Timing belt tensioner Timing Belt/Water Pump Service Only - $499 Brake Packages http://www.iagperformance.com/images/forum/nasioc/service/image_07_800.jpg Stage 1 Hawk HPS Front/Rear Pads Techna-Fit SS brake lines Motul DOT 5.1 or Ate SuperBlue LGT - $499 Installed Prices Vary - Also available for other Subaru models - Call/PM for details and pricing! Stage 2 Hawk HPS Front/Rear Pads Techna-Fit SS Brake Lines Motul DOT 5.1 or Ate SuperBlue DBA 4000 Series Slotted Rotors LGT- $1049 Installed Prices Vary - Also available for other Subaru models - Call/PM for details and pricing! Suspension Services http://www.iagperformance.com/images/forum/nasioc/service/image_06_800.jpg Alignment/Corner Balancing Performance Alignment - $99 Performance Alignment & Corner Balancing - $199 Install Springs/Coilovers (purchased @ IAG) w/ Performance Alignment - $250 Install Customer supplied springs & alignment - $349 Install Customer supplied coilovers & alignment - $399 Fender Rolling Services http://www.iagperformance.com/images/forum/nasioc/service/image_07_800.gif $99 - Roll rear fenders $125 - Roll & pull rear fenders $150 - Roll all 4 corners $199 - Roll & pull all 4 corners Fender rolling service pricing may vary depending on vehicle/extent of service - Call/PM for details! Transmission Services http://www.iagperformance.com/images/forum/nasioc/service/image_08_800.jpg Exedy Stage 1 clutch package – w/ resurfaced flywheel & Motul or Eneos 75w90 fluid LGT & 06 Spec B - $899 Installed 07+ Spec B- $999 Installed Prices Vary - Also available for other Subaru models - Call/PM for details and pricing! Exedy Twin-Plate clutch package w/ performance flywheel & Motul or Eneos 75w90 fluid LGT & 06 Spec B- $1999 Installed 07+ Spec B - $2099 Installed Prices Vary - Also available for other Subaru models - Call/PM for details and pricing! Other clutch purchased @ IAG installation prices (includes resurfacing flywheel and choice of synthetic transmission fluid) LGT & 06 Spec B - $399 07+ Spec B- $499 Install customer supplied clutch (includes resurfacing flywheel and choice of synthetic transmission fluid) 5spd - $499 6Spd - $549 New ACT Specials (others available - PM/Call for details!) Performance Part Installs Downpipe/Turboback (purchased @ IAG) - $79 Downpipe/Turboback (customer supplied) - $99 Single Outlet Exhaust - $118 Dual Outlet Exhaust (LGT/08+STI) Uppipe Install (purchased @ IAG) - $237 Uppipe Install (customer supplied) - $276 Sway-Bar/end-link Install (purchased @ IAG) - $79 Sway-Bar/end-link Install (customer supplied) - Varies by platform - Call or PM Upgraded Turbo Install - Varies - Please call or PM Front-Mount Intercooler Install - Please call or PM The IAG Performance Rotated Turbo Setup - Please call or PM Installation of thousands of other products for your Subaru - PM for pricing!!! Protuning by Jorge (riftswrx) $500 for 2 hour tuning session $99 for IAG Pre-Dyno Inspection - Includes compression test and check for boost leaks - Complimentary full-support on the dyno if this service is performed prior to tuning! Contact us for tuning dates. Appearance Services & Window Tint http://iagperformance.com/images/forum/nasioc/service/image_09_800.jpg Window Tinting @ IAG Performance Our window tinter has been in the business for over 15 years, and does an absolutely incredible job. We offer Johnson high quality window films, available in shades from MD legal all the way to limo dark. Our tinting services come with a lifetime warranty against bubbling, peeling, fading, purpling, hazing, & more. If you're looking for high-quality tint for your Subaru, shoot us a PM or call at the shop any time! Other Appearance Services Recondition headlights - $75 Koji-Mod & Paint headlights (your choice of color, typically black) $299 Headlight and Taillight Protection Films - Price varies - PM for details! IAG Performance 1203 Baltimore Blvd. Westminster, MD 21157 410-840-3555 www.iagperformance.com sales@iagperformance.com Link to comment Share on other sites More sharing options...
IAG Performance Posted January 4, 2011 Author Share Posted January 4, 2011 IAG is proud to announce that we now offer a full range of mobile electronics services. We are offering some specials to kick off our expansion into the field so don’t miss out on these opportunities. We stand behind what we install and everything is backed by a lifetime workmanship guarantee! This Month's Specials Products are offered for install only, and all prices include install. http://www.iagperformance.com/images/forum/nasioc/service/image_11_800.jpg Viper 5901 - $550* installed Remote Start, Keyless Entry, Security. Responder LC3 – the 3rd generation of Responder, complete with SST One Mile Range, the new Priority icons and text seen on a 20% larger liquid-crystal display, an onboard lithium-ion rechargeable battery with mini-USB recharging – all in the slimmest display remote on the market. --Compatible with the new Viper Smart Start System. Control your alarm system with a compatible Iphone or Blackberry. http://www.iagperformance.com/images/forum/nasioc/service/image_13_800.jpg Avital 5303 - $400* installed Remote Start, Keyless Entry, Security. Avital's top-of-the-line security and remote start system will start your car with the push of a button from up to 1,500 feet away – and confirm it has started on the large LCD screen of the 2-way remote. Security works the same way: when you arm or disarm your system, you will receive confirmation on the 2-way remote, and if your siren sounds the remote will beep or vibrate to let you know, from up to 1,500 feet away. System comes with one 2-way and one 4-button 1-way remote. http://www.iagperformance.com/images/forum/nasioc/service/image_14_800.jpg Viper 4103xv - $225* Installed Remote Start, Keyless Entry Viper’s basic remote start and keyless entry solution. Includes two four button ergonomic transmitters with a range up to 1,500 feet. http://www.iagperformance.com/images/forum/nasioc/service/image_15_800.jpg Avital 3100 - $225 Installed Alarm and Keyless Entry When it’s peace of mind you’re looking for, Avital delivers in the affordable 3100. Control your system with two 3-button Avital remotes with range up to 1,500 feet. * All LGT’s require an additional $50 for Immobilizer module. 2005+ STI, LGT 2006+ WRX, FXT Require a key for operation of remote start. We now carry the full line of Viper, Avital, and Directed accessories. You can even customize your setup with additional features. Including remote trunk release, remote window control, and additional sensors and/or sirens. Contact us for details. GPS We now also carry Guidepoint GPS tracking systems. Similar to LoJack, these units offer stolen vehicle recovery but also go above and beyond with additional features and services. Guidepoint uses a state-of-the-art computer module that's equipped with a global positioning satellite (GPS) receiver, wireless data modem and vehicle interface component that allows us to "talk and listen to the car." Each unit's unique electronic serial number-similar to a cell phone number-allows information to be sent back and forth between the vehicle and Guidepoint's Response Center over a nationwide wireless network. Available features and options: -GPS Vehicle Locator: Log onto and track the whereabouts of your vehicle at any time of the day over the internet. -Stolen Vehicle Recovery: Real-time Internet Tracking of your stolen vehicle 24/7 by trained ResponseCenter personal for faster recovery. -E-Call & Roadside Assistance: In the event of an emergency situation of any kind, this feature provides appropriate emergency assistance or towing to the vehicle’s exact location with a single phone call. -Geographic Boundary Alerts: Set geographic limitations in which your vehicle can travel. If your vehicle travels outside of your predetermined boundaries, you’ll receive an automated alert via email or text message. -Selectable Excessive Speed Notification: This feature allows you to track the speed your vehicle is traveling and provides you with electronic alerts any time your vehicle exceeds a pre-selected speed for a given amount of time. -Trace Maps: With this online feature, you can review a history or trace map of where your vehicle has been. -Arrival and Departure Alerts: Receive email or text notifications when your vehicle arrives or departs from a designated waypoint or landmark. -Selectable Features: Add security and convenience with selectable features including Remote Door Unlock, Remote Carfind and Remote Car Start. (may require additional parts and labor). -Visual Theft Deterrent: The Guidepoint access panel mounted on your dash is a visual indicator that your system is on and your vehicle is protected. This panel also allows for access to optional services. -Transferable: If you ever sell or trade your vehicle, your Guidepoint GPS System can be transferred to your next vehicle. -On-Call: 24/7/365 ResponseCenter access at the touch of a button. -Electronic Security Fence: The Guidepoint Unit automatically sets an Electronic Security Zone around your vehicle each time you leave it. -Automatic Theft Notification: If your vehicle is moved outside the electronic security fence a theft notification is sent to the ResponseCenter. As soon as the ResponseCenter receives the alert, one of our trained professionals will contact you at your designated contact number. --Contact us for pricing and options. Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted January 4, 2011 Share Posted January 4, 2011 Though I have yet to visit their shop. Props to IAG, everyone seems to love them and Rick is a cool guy. See yall ina couple of weeks. Sooner if i get the time to swing by there. Link to comment Share on other sites More sharing options...
brewhaha Posted January 4, 2011 Share Posted January 4, 2011 I've been wanting to swing by the shop sometime. Hard to get that kind of spare time though. Hopefully I'll make the meet. Link to comment Share on other sites More sharing options...
HarryN Posted January 4, 2011 Share Posted January 4, 2011 Good God... is there anything IAG doesn't do?? That's awesome! Thanks for the post OP! Link to comment Share on other sites More sharing options...
TheWeatherWarrior Posted January 5, 2011 Share Posted January 5, 2011 Good God... is there anything IAG doesn't do?? That's awesome! Thanks for the post OP!Body Work? I have to laugh a bit at the pulled/rolled fender graphic. They are true to the effects of pulling....which enlarges the hood/fender gap. Prices aren't too bad on the maintenance stuff since it seems some of the fluids and misc. items a are a tad better than a traditional place. The crime is just in how much "everyone" charges for labor these days. I'll be up at the meet hopefully (pending my DIY repairs). It will be nice to see another shop for when (if..lol) I get my income to a level to afford the goodies for IAG and the like. Link to comment Share on other sites More sharing options...
IAG Performance Posted January 5, 2011 Author Share Posted January 5, 2011 Body Work? I have to laugh a bit at the pulled/rolled fender graphic. They are true to the effects of pulling....which enlarges the hood/fender gap. Prices aren't too bad on the maintenance stuff since it seems some of the fluids and misc. items a are a tad better than a traditional place. The crime is just in how much "everyone" charges for labor these days. I'll be up at the meet hopefully (pending my DIY repairs). It will be nice to see another shop for when (if..lol) I get my income to a level to afford the goodies for IAG and the like. ACTUALLY...we do body work! We have just built a state of the art body shop and have multiple full time body guys on hand. http://iagcollision.com/ -Greg Link to comment Share on other sites More sharing options...
LegacyGTBiggie Posted January 5, 2011 Share Posted January 5, 2011 they officially do it all....NICE Link to comment Share on other sites More sharing options...
IAG Performance Posted January 5, 2011 Author Share Posted January 5, 2011 By the way, we do have a few tuning spots available for this coming weekend. Call or email me. -Greg Greg@IAGPerformance.com 410-840-3555 Link to comment Share on other sites More sharing options...
musty_hustla Posted January 30, 2011 Share Posted January 30, 2011 Is an appointment recommended for a weekend visit? Link to comment Share on other sites More sharing options...
IAG Performance Posted January 31, 2011 Author Share Posted January 31, 2011 Absolutely. We are booked out about 2 weeks right now. We are open from 10-5 on Saturday and closed on Sunday. Shoot me a PM with what you are looking to get done. Link to comment Share on other sites More sharing options...
IAG Performance Posted February 4, 2011 Author Share Posted February 4, 2011 Bump! Check out our Used parts section: http://iagperformance.com/shopping_cart/categories.php?cat=891 Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted February 9, 2011 I Donated Share Posted February 9, 2011 How much for a boost leak check? Link to comment Share on other sites More sharing options...
IAG Performance Posted February 9, 2011 Author Share Posted February 9, 2011 Pm sent. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted February 10, 2011 I Donated Share Posted February 10, 2011 PMed you back. Waiting on a response. Link to comment Share on other sites More sharing options...
IAG Performance Posted February 10, 2011 Author Share Posted February 10, 2011 PMed you back. Waiting on a response. PM replied! Link to comment Share on other sites More sharing options...
joedirtae09 Posted February 15, 2011 Share Posted February 15, 2011 BUMP for great service!! I took my car in last week to get some parts installed and they did it super fast and for a great price!! Link to comment Share on other sites More sharing options...
IAG Performance Posted February 16, 2011 Author Share Posted February 16, 2011 Thanks for the kind words. Glad you had a great experience! -Greg Link to comment Share on other sites More sharing options...
TheWeatherWarrior Posted February 18, 2011 Share Posted February 18, 2011 To IAG: I know it's not realistic to get a real number, but gonna ask anyway. About what would be the cost of a new (or rebuilt used) 2.5L non-turbo for my 1997 Legacy GT Wagon ball park at (included swapping the motor). What if I keep the existing motor (to rebuild myself as a spare motor, or go full hog performance on (-core exchange value). The motor I want really would be best if it's geared for better MPGs and not performance. I would love to get a car back to around 25/30 mpg (city/hwy). With the amount of miles I could put on the car, the difference would almost pay for itself after three years (verses doing the motor swap head gaskets myself). +7mpg hwg ~ 10,000 hwy miles per year = 101 gallons per year savings @ 3.50/gal. = $355 savings per year Link to comment Share on other sites More sharing options...
Leonardo Posted February 21, 2011 Share Posted February 21, 2011 Damn, wish I were closer to you guys! Link to comment Share on other sites More sharing options...
IAG Performance Posted February 21, 2011 Author Share Posted February 21, 2011 To IAG: I know it's not realistic to get a real number, but gonna ask anyway. About what would be the cost of a new (or rebuilt used) 2.5L non-turbo for my 1997 Legacy GT Wagon ball park at (included swapping the motor). What if I keep the existing motor (to rebuild myself as a spare motor, or go full hog performance on (-core exchange value). The motor I want really would be best if it's geared for better MPGs and not performance. I would love to get a car back to around 25/30 mpg (city/hwy). With the amount of miles I could put on the car, the difference would almost pay for itself after three years (verses doing the motor swap head gaskets myself). +7mpg hwg ~ 10,000 hwy miles per year = 101 gallons per year savings @ 3.50/gal. = $355 savings per year Call us to discuss:410-840-3555 Damn, wish I were closer to you guys! It's not that far... Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted March 2, 2011 I Donated Share Posted March 2, 2011 Do you have the Prosport oil galley plug adapter? Link to comment Share on other sites More sharing options...
Leonardo Posted March 2, 2011 Share Posted March 2, 2011 Would the motul 75w90 be the one used for the LegGT rear diff? Link to comment Share on other sites More sharing options...
TheWeatherWarrior Posted March 2, 2011 Share Posted March 2, 2011 Call us to discuss:410-840-3555Dropped a call to ya around 1pm. Sorry for the long message. Hope you guys can give me a call back today, will be out tomorrow and possible Friday. Link to comment Share on other sites More sharing options...
IAG Performance Posted March 2, 2011 Author Share Posted March 2, 2011 Do you have the Prosport oil galley plug adapter? Yes we have them in stock! Would the motul 75w90 be the one used for the LegGT rear diff? That is correct. That's what's in my rear diff. Dropped a call to ya around 1pm. Sorry for the long message. Hope you guys can give me a call back today, will be out tomorrow and possible Friday. We'll get back to you! Probably not today, but we will. Link to comment Share on other sites More sharing options...
