Mel2058 Posted January 2, 2011 Share Posted January 2, 2011 I have been searching all over this forum to find a turbo to replace mine. Who has one available with low miles on it or where would be the best place to find one online at a low price? Also what would have to be done if i went with a vf46? Link to comment Share on other sites More sharing options...
SBT Posted January 2, 2011 Share Posted January 2, 2011 VF 46 is essentially a direct replacement. Others are available but would require tuning at a minimum and supporting mods. Check out the BNR turbos. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Mel2058 Posted January 2, 2011 Author Share Posted January 2, 2011 So getting a vf46 would just be a bolt in or would it require tuning? Link to comment Share on other sites More sharing options...
SBT Posted January 3, 2011 Share Posted January 3, 2011 I retuned when I replaced my VF40. Others have just bolted it on. There's definitely differences in delivery between the two, so YMMV. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
subiedad51 Posted January 3, 2011 Share Posted January 3, 2011 You could go without a tune but it's best to get tuned. The 46 spools a bit quicker than the 40 so there's definitely some differences there. You could go with the 46 and get an infamous tune. There's also a used VF52 with 18k miles for sale on Nasioc for $600. There you would need a tune for sure but you'd be looking at more upside. Of course, there are more non VF options as well like the BNRs. Really depends on what your goals and future goals are for the car. Link to comment Share on other sites More sharing options...
mrTOPSPEED Posted January 6, 2011 Share Posted January 6, 2011 So what does a VF46 with an catless up- and down-pipe do on an 05? I just bought an 05 with a engine that needs a new bottom end as well as a turbo ... so I might as well upgrade while I have evt'g apart. Link to comment Share on other sites More sharing options...
subiedad51 Posted January 6, 2011 Share Posted January 6, 2011 The 46 spools a bit quicker than the 40. That and they seem to be more reliable than the 40's although people will debate that. Other than the quicker spool it's pretty much the same turbo. Link to comment Share on other sites More sharing options...
SBT Posted January 6, 2011 Share Posted January 6, 2011 And there seems to be a marginal bit more top end (barely and mostly tune-dependent). - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
jaxx4k Posted February 22, 2011 Share Posted February 22, 2011 I'm on this VF40/46 wagon too now.. I just finish a stg2 tune w/vf40 & now found out the turbo is spitting out oil on the compressor side-TMIC. quicker spool = lean or richer?? I'm thinking bout going with out a tune as well. another turbo + tune is way out of my price range right now... Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 22, 2011 Share Posted February 22, 2011 I just finish a stg2 tune w/vf40 & now found out the turbo is spitting out oil on the compressor side-TMIC.... Change your pcv. I bet you are on the oem og pcv and your cv is off. Link to comment Share on other sites More sharing options...
jaxx4k Posted February 22, 2011 Share Posted February 22, 2011 Cv? Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted February 22, 2011 Share Posted February 22, 2011 crankcase vent search pcv Link to comment Share on other sites More sharing options...
