LoHud 3.6R Posted January 21, 2011 Share Posted January 21, 2011 Seiyafan, we have the same whip. R u still using stock tires and if so what PSI r u using? Link to comment Share on other sites More sharing options...
seiyafan Posted January 21, 2011 Author Share Posted January 21, 2011 no, i changed to DWS a week ago. I had 37.5/36 before then I lowered it to 35/33 because the ride was not complient, only to found out a few days later one of the tires was badly out of balance. I have not bothered to increase the pressure since but the ride is a lot better now. Link to comment Share on other sites More sharing options...
SBT Posted January 22, 2011 Share Posted January 22, 2011 48 on all 4 Yeah - that's going to be hard on your AWD and your fillings... Plus at those pressures, you're not leaving enough "expansion" room for the pressure when the tires are hot. I know that high-speed driving in San Diego in the Summer, even worse in Anza Borrego, that I could see a 5-8 PSI increase in tire pressures, from cold. Check your sidewalls to see what the max tire pressures your tires are rated to. My Z-rated are rated to 50 PSI max. If you're running at 48 PSI, then you're likely over your max. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
