awwsheeet Posted December 29, 2010 Share Posted December 29, 2010 there has to be someone who has done this. aftermarket wheels are ok! i got winter tires for gratis and would like to use them Link to comment Share on other sites More sharing options...
Drift Motion Posted December 29, 2010 Share Posted December 29, 2010 sad thing is that...no because LGT brakes needs 17inch wheel minimum...do a search next time please Link to comment Share on other sites More sharing options...
blaze741 Posted December 29, 2010 Share Posted December 29, 2010 you can't fit 16's on ur gt because of your brakes are too large. only 2.5i models can fit 16's. Link to comment Share on other sites More sharing options...
awwsheeet Posted December 29, 2010 Author Share Posted December 29, 2010 i bet theres a aftermarket wheel that can do it. like a kosei k1. is it hitting the outter rim or the inside of spokes? whats the size of a lgt brake?? Link to comment Share on other sites More sharing options...
Drift Motion Posted December 29, 2010 Share Posted December 29, 2010 kosei is just some shitty knock off wheels and its the diameter that doesnt fit, not the spoke design that is preventing the 16inch wheel from fitting Link to comment Share on other sites More sharing options...
Scooby Fan Posted December 29, 2010 Share Posted December 29, 2010 If you really "Have" to do this....there was a guy quite a while ago posted that he did it by taking a grinder to the calipers where they rubbed..."Claimed" there was adequate material to grind away the caliper and use 16" wheels......do at "Your own risk" A detailed "search" might find it...I filed it under "Do NOT ever read this post again" Link to comment Share on other sites More sharing options...
Frogg Posted December 30, 2010 Share Posted December 30, 2010 grinding calipers is very common...but just be sure to do it carefully or you'll need to buy a new one. Link to comment Share on other sites More sharing options...
mariuzs Posted December 30, 2010 Share Posted December 30, 2010 yeah, fitting 16'' on lgt is my current issue too, thinking about downgrade front brakes to wrx ones Link to comment Share on other sites More sharing options...
