Crazy8 Posted December 24, 2010 Share Posted December 24, 2010 Here's a log with the 1.6.4 beta firmware. I've been looking to see if I have knock issues. The knock sum #4 has loads of hits - not sure what is happening there. Thoughts?datalog21.csv Link to comment Share on other sites More sharing options...
rtbrjason Posted December 24, 2010 Share Posted December 24, 2010 Most of those knocks in your log over 3k rpm are probably real knock events. The knock sensor is fairly accurate over 3k rpms. Most of that is happening when you go wot at around 3300+ rpm. I noticed a couple in the 4k plus range too which is not ideal imo. Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted December 28, 2010 Share Posted December 28, 2010 holy slow sample rate batman! turn off some of those monitors, it's hard to get a good idea of what's going on when you get 4-5 samples per second On the search for a new DD... Link to comment Share on other sites More sharing options...
