WRXTom Posted June 21, 2004 Share Posted June 21, 2004 A few suspension questions: 1. Can anyone provide detail on the USDM, Japan-spec and STi spring rates? 2. Are the USDM and Japanese struts the same spec? Also, if the answer to 2. is "no" then what will be the compatibility to USDM of the STi springs that are currently available in Japan? *edit* - and, if necessary, will STI make USDM specific springs. I realize it is early so we are just guessing at this point. Tom Link to comment Share on other sites More sharing options...
eavr4 Posted June 21, 2004 Share Posted June 21, 2004 [quote name='WRXTom']A few suspension questions: 1. Can anyone provide detail on the USDM, Japan-spec and STi spring rates? 2. Are the USDM and Japanese struts the same spec? Also, if the answer to 2. is "no" then what will be the compatibility to USDM of the STi springs that are currently available in Japan? Tom[/quote] Hi Tom, Following threads maybe of interest to you... [url]http://www.subaruclubsg.com/phpBB2/viewtopic.php?t=13125[/url] [url]http://www.subaruclubsg.com/phpBB2/viewtopic.php?t=13213[/url] [url]http://www.subaruclubsg.com/phpBB2/viewtopic.php?t=13206[/url] [url]http://www.subaruclubsg.com/phpBB2/viewtopic.php?t=13354[/url] Cheers! EA Link to comment Share on other sites More sharing options...
WRXTom Posted June 21, 2004 Author Share Posted June 21, 2004 Registering now. Thanks, Tom Link to comment Share on other sites More sharing options...
racerdave Posted June 21, 2004 Share Posted June 21, 2004 Tom, Any chance you could post up the answers to your original question here? Link to comment Share on other sites More sharing options...
Drift Monkey Posted June 22, 2004 Share Posted June 22, 2004 [quote name='racerdave']Tom, Any chance you could post up the answers to your original question here?[/quote] Yes, we all don't want to have to sign up! Link to comment Share on other sites More sharing options...
WRXTom Posted June 22, 2004 Author Share Posted June 22, 2004 I'll just copy and paste. Not sure what it means yet as far as options for USDM since our struts may or may not be compatible with these spring rates. Posted: Tue Jun 08, 2004 3:54 pm Post subject: Replacement Springs available for BL5 -------------------------------------------------------------------------------- Tanabe NF210 : (FR) -20-30mm, 3.5kg/mm (RR) -15-25mm, 5.4kg/mm Sti : (FR) -15mm, 4.0kg/mm (RR) -15mm, 6.0kg/mm Kg/mm : (FR) -15mm, 3.6kg/mm (RR) -15mm, 7.8kg/mm Blitz : (FR) -25-30mm, 4.3kg/mm (RR) -15-20mm, 7.2kg/mm Ti2000 : (FR) -40-35mm, 4.38kg/mm (RR) -30-25mm, 4.84kg/mm RS*R : (FR) -40-35mm, 4.38kg/mm (RR) -30-25mm, 4.84kg/mm Tein H-Tech : (FR) -15mm, 3.1-4.7kg/mm (RR) -15mm, 4.1-6.5kg/mm Tein S-Tech : (FR) -25mm, 2.7-5.3kg/mm (RR) -25mm, 3.6-7.2kg/mm Also, the below cut & paste shows some of the activity around the ECU in Japan (perhaps USDM versions to follow). Have received response from Mines and Zero Sports that they now have Plug-n-play ECUs for our car Mines - NEW VX-ROM features burning pitch ignition timing, speed delimiter (JDM models), extended rev limit (>7500 rpm), extended boost limit (>1.37bar) Zerosports - S.P.DATAR TYPE ZERO (Max 1.0 bar) for light tuned engines - S.P.DATAR TYPE 1 (Max 1.2 bar) for light tuned engines and exhaust - S.P.DATAR TYPE 2 (Max 1.2 bar) for light tuned engines plus decat - S.P.DATAR TYPE 3 (Max 1.2 bar) Hard tuned including increased fuel pressure, injection duty cycle, Air/fuel optimised Cheers, Tom Link to comment Share on other sites More sharing options...
eavr4 Posted June 23, 2004 Share Posted June 23, 2004 Wrx Tom,....I also found I think is the ECU diagram for the USDM 25GT do you want? As I do not have USDM 25GT ECU I cannot verify however compared with the 20GT (JDM) diagram quite similer in most of the pinouts but most significant difference is the Cruise control pins... EA Link to comment Share on other sites More sharing options...
Xenonk Posted July 20, 2004 Share Posted July 20, 2004 25GT USDM diagram pin out please :D Keefe Keefe Link to comment Share on other sites More sharing options...
