TheBoostNazi Posted June 7, 2011 Share Posted June 7, 2011 Classic case of torque converter not locked up. when the car is on the dyno, it shows the same thing right? So do they determine peak hp/tq after the tc locked up? is that even accurate? Link to comment Share on other sites More sharing options...
bbarnhill Posted June 11, 2011 Share Posted June 11, 2011 Its accurate if the torque converter is locked up. Before that it is NOT accurate. Link to comment Share on other sites More sharing options...
cd_legacy Posted June 15, 2011 Share Posted June 15, 2011 I cant seem to get this to work. (Error E101: Not all columns needed for calculations found) What exactly do I need to log? Link to comment Share on other sites More sharing options...
PartyRock Posted June 15, 2011 Share Posted June 15, 2011 I cant seem to get this to work. (Error E101: Not all columns needed for calculations found) What exactly do I need to log? time, throttle plate opening angle, engine rpm, engine load Link to comment Share on other sites More sharing options...
bbarnhill Posted June 17, 2011 Share Posted June 17, 2011 Technically all that is required is RPM, TIME, and TPS ... other than that you have the option for BOOST and AFR. Now if it continues to do that and you have logged those columns, when it asks you if you want to send a copy to the developer ... CLICK YES!!! Ill add the columns and push out an update. Sometimes there are columns in these logs I haven't seen. Link to comment Share on other sites More sharing options...
cd_legacy Posted June 17, 2011 Share Posted June 17, 2011 Technically all that is required is RPM, TIME, and TPS ... other than that you have the option for BOOST and AFR. Now if it continues to do that and you have logged those columns, when it asks you if you want to send a copy to the developer ... CLICK YES!!! Ill add the columns and push out an update. Sometimes there are columns in these logs I haven't seen. Ok, thanks...Also when will there be a manual LGT in the drop down menu? Can I just choose a WRX maual trans and have it work properly as long as I change the weight? Link to comment Share on other sites More sharing options...
PartyRock Posted June 17, 2011 Share Posted June 17, 2011 Ok, thanks...Also when will there be a manual LGT in the drop down menu? Can I just choose a WRX maual trans and have it work properly as long as I change the weight? You need to change the gear ratios. They're different. Go in to the install directory and edit the xml file. Link to comment Share on other sites More sharing options...
bbarnhill Posted June 19, 2011 Share Posted June 19, 2011 why dont someone send me the info on the LGT manual? Send it to me in this format: <CarParameters> <CarMake>Chevrolet</CarMake> <CarModel>Cavalier</CarModel> <CarSubModel>Ecotec 2.2</CarSubModel> <StartYear>2002</StartYear> <EndYear>2005</EndYear> <Weight>2600</Weight> <TransTypeManual>true</TransTypeManual> <TransGear3>1.35</TransGear3> <TransGear4>0.98</TransGear4> <FinalGearRatio>3.84</FinalGearRatio> <DragCoefficient>0.36</DragCoefficient> <FrontalArea>20.2</FrontalArea> <TireDiameter>24.9</TireDiameter> </CarParameters> If you have 1.1.0 or higher you will receive an update automatically when I add it Thats the main feature in 1.1.0 is the auto update capability of the app, car defs, and column defs. Link to comment Share on other sites More sharing options...
bbarnhill Posted July 5, 2011 Share Posted July 5, 2011 Hum ... what if we could graph any column along side HP and TQ ... just wondering what you all thought? Link to comment Share on other sites More sharing options...
