amorgan93 Posted December 15, 2010 Share Posted December 15, 2010 Just sitting here planning how to spend money i dont have. How much boost could a EJ22E (1990) take with EJ22T Crank & rods (or does the N/A have the same crank? rods?) and a set of forged pistons, with new rings, new rod bearings, new headgasket (using headgasket designed for EJ22T?), new seals, etc? most likely a VF-11 turbo from a EJ22T. or if you can make a recommendation? also i would use exhaust system from a turbo ej22. injectors from a ej22t? or is there a better injector for reasonable price? also probably just use piggyback to control air/fuel. or can the stock ECU even handle bigger injectors with piggyback? or would i have to use ECU from turbo car? don't tell me to find a ej22t and swap or a donor turbo car cause ive looked and have yet to find a salvaged turbo car. Link to comment Share on other sites More sharing options...
ehsnils Posted December 15, 2010 Share Posted December 15, 2010 Don't forget pistons, and possibly cylinder heads too. It will be cheaper to actually fetch the engine from a later WRX or something and make a transplant. And the ECU has to be replaced, the stock one doesn't understand "Turbo". Link to comment Share on other sites More sharing options...
subikid90 Posted December 15, 2010 Share Posted December 15, 2010 There is a salvage ss turbo on the sales list right now. I would try to find EJ22T heads and rebuild them and port and polish. A well built open deck EJ motor can take 20-25 psi if it is tuned properly. And I mean you need to put it on a dyno and pay someone to tune it. But thats expensive so to be safe I would say 10-15psi with a preloaded map on a PP6 or a similar piggyback. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
