shtbxr22 Posted December 14, 2010 Share Posted December 14, 2010 I have an 08 Spec B. I have an ACT setup for an 07 STi (SB4-XTSS and 600235) will it work? Link to comment Share on other sites More sharing options...
rtbrjason Posted December 14, 2010 Share Posted December 14, 2010 Aside from the clutch, you also need a pressure plate and bearing (all included if you have the clutch kit). You will also need an STI fitment flywheel. Stock or aftermarket is fine. I have the HDSS and ACT Streetlight flywheel in my 08 spec b. They were 04+ sti fitment parts. Link to comment Share on other sites More sharing options...
shtbxr22 Posted December 14, 2010 Author Share Posted December 14, 2010 excellent! yeah, it's complete. I have the clutch disc/pressure plate/TOB/PB/alignment tool/flywheel. No check engine light with the streetlite? Link to comment Share on other sites More sharing options...
rtbrjason Posted December 14, 2010 Share Posted December 14, 2010 No check engine light. It's still about 15lbs so it has some weight to it. I believe the 11lb (prolite) can start to cause cels. Link to comment Share on other sites More sharing options...
shtbxr22 Posted December 14, 2010 Author Share Posted December 14, 2010 Cool, that's what i wanted to avoid. Thanks for the help. Link to comment Share on other sites More sharing options...
