amorgan93 Posted December 14, 2010 Share Posted December 14, 2010 i finally figured out that i was pulling the codes wrong on my subaru. this time i disconnected the memory wire and plugged in the black connectors that are beside the green ones. i was suprised to be given 4 different codes. 24-Air control valve or circuit (exc. Justy); Idle speed control solenoid valve (Justy) 31-Throttle position sensor or circuit 35-Canister purge solenoid or circuit 49-Airflow sensor dont know if these are codes that were stored or if they are the active problems. I replaced the TPS from a 92 legacy donor car. i removed the idle air control valve and cleaned and tried to run the car several times and had forgot to plug it up. Could be why its showing that code. seems like i also tried to run the car with the TPS not plugged up. No clue what the canister purge solenoid is, and i replaced the airflow sensor with that from the 92 donor car, and the sensor was perfectly clean and looked fine. any way to reset the computer to make sure these codes arent just from my stupid mistakes? i tried leaving the car unplugged for a good 2 days and that still didnt reset it. Link to comment Share on other sites More sharing options...
subikid90 Posted December 14, 2010 Share Posted December 14, 2010 Unplug your negative battery terminal and press the brake petal for 30 sec then leave the battery unplugged for an hr or longer. That will clear all your codes -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
