2005gt35r Posted December 5, 2010 Share Posted December 5, 2010 my dads car fouled another plug....hopefully. same symptoms, cruise light blinking, check engine light on, running like crap. is this common to happen in these cars? im fixing it tomorrow in school so its not that big of a pain. the last time i replaced a plug in it, the plug i got out was not a plug that was recommended for the car, also the threads were alot longer than the new spark plugs. could this be the cause? Link to comment Share on other sites More sharing options...
frank_ster Posted December 5, 2010 Share Posted December 5, 2010 Could be. But plug fouling could be faulty coil or low compression on that cylinder. FYI always check the length of spark plugs!!!! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
jfg22557 Posted December 6, 2010 Share Posted December 6, 2010 ensure your not using a plug coded for a 2.5i (non-turbo). I cant recall which is which, but the different length plugs determine their application ( 2.5T or 2.5i). Mistaking an n/a plug for a turbo plug will undoubtedly cause misfiring and general "running like crap" as you said. hope this helped -Jake Link to comment Share on other sites More sharing options...
ehsnils Posted December 6, 2010 Share Posted December 6, 2010 Many factors that can foul a plug, but it's also how it's fouled. Is it plain soot or is there oil residue? No oil is a good sign, and then you should check coil, injector and valve clearance and also check compression figures in case there is a burnt/damaged valve. Link to comment Share on other sites More sharing options...
GTTuner Posted December 6, 2010 Share Posted December 6, 2010 NA plugs are designated with a "11" at the end of the part number. Some guys use then and close up the gap because the 11 denotes wide gap. Link to comment Share on other sites More sharing options...
ehsnils Posted December 6, 2010 Share Posted December 6, 2010 And "11" means 1.1 millimeters. Link to comment Share on other sites More sharing options...
GTTuner Posted December 6, 2010 Share Posted December 6, 2010 or .044" Link to comment Share on other sites More sharing options...
2005gt35r Posted December 6, 2010 Author Share Posted December 6, 2010 well when the car got up on the lift, first look all i see is a coil with no electrical plug on it and the plug hanging next to it. plug her in and she runs fine. all good, thanks for the help guys. Link to comment Share on other sites More sharing options...
frank_ster Posted December 6, 2010 Share Posted December 6, 2010 Nah. That cant be it better sellthe car! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
