amorgan93 Posted December 3, 2010 Share Posted December 3, 2010 i replaced the check engine bulb in my guage cluster, and the check engine light comes on and stays on. i was trying to diagnose by plugging in the green connectors, but i couldn't find the black connectors to disconnect the memory wire or whatever like [ame=http://www.youtube.com/watch?v=3GEYepYzyiY]THIS[/ame] video shows. The radiator fan switches high power, then low power, then high power, and repeats this, but the check engine light never flashes. Link to comment Share on other sites More sharing options...
Jester808 Posted December 3, 2010 Share Posted December 3, 2010 http://surrealmirage.com/subaru/engine.html Link to comment Share on other sites More sharing options...
amorgan93 Posted December 3, 2010 Author Share Posted December 3, 2010 fixed, it. realized i have to crank the car. I am having a code 11 show up which is crank angle sensor/Ignition pulse system. doesnt make sense the car would even run if the crank angle sensor is bad. It idles fine when cold, but after warming up it idle surges and will eventually die. also when i rev past 3000 rpm the motors sound will change and it will die already tried cleaning IAC valve. Link to comment Share on other sites More sharing options...
