LittleBlueGT Posted December 13, 2010 Author Share Posted December 13, 2010 Everything for the clutch works just fine, car is finally running again. Engine has great compression, leak down test was 2 or 3%. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
SCGT Posted December 15, 2010 Share Posted December 15, 2010 Good luck with UPS. Don't give up the fight. I fought them for 6 months on a $500 amplifier being damaged and finally won. They packed it, insured it, shipped it, damaged it, then denied the claim. Yep, you read it right, I paid them to pack it, and it was deemed "improperly packaged" and my claim denied. You can't make this stuff up. Keep after it and good luck. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted December 15, 2010 Author Share Posted December 15, 2010 2mm should not cause contact. I just dont know how "tight" the valves were? -30c? FACK! I knew a couple of guys from Edmonton. They used to joke about -30c. I guess it was no joke. Sounds like this has been an experience all around. I feel for you. I seem to have the same "luck" when it comes to these things. FWIW the worst valve was off by 0.4 mm. Not sure how this mix-up happened, but it is all good now. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
m sprank Posted December 16, 2010 Share Posted December 16, 2010 0.35 is max clearance. Tight tolerances. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted December 16, 2010 Author Share Posted December 16, 2010 0.35 is max clearance. Tight tolerances. That means the clearance you have to get when adjusting valve lash, not the pisont to valve clearance. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
m sprank Posted December 16, 2010 Share Posted December 16, 2010 ^ Yes. Thats why I am surprised that 0.4mm caused such a problem. Goes to show how touchy the motors are. I dont see how you could have contacted the piston at such a small deviance. Makes me think I should get new feeler gauges. I am sure mine are a little worn from use. Link to comment Share on other sites More sharing options...
LittleBlueGT Posted December 17, 2010 Author Share Posted December 17, 2010 ^ Yes. Thats why I am surprised that 0.4mm caused such a problem. Goes to show how touchy the motors are. I dont see how you could have contacted the piston at such a small deviance. Makes me think I should get new feeler gauges. I am sure mine are a little worn from use. I guess it was enough to cause no compression. Keep in mind it is less for intake valves. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
m sprank Posted December 17, 2010 Share Posted December 17, 2010 Not much. But yes, you obviously were not compressing enough to get combustion. Good thing once its set it does not need constant checking and adjusting. Like an air cooled Honda. I am not the biggest fan of setting valve clearance on shim under bucket motors. So many years of rocker arms and then all the sudden I need a chart and a calculator to set valve clearance. Plus a box of EXPENSIVE shims. I sound more and more like my old man every day. "Back when I was younger..." Link to comment Share on other sites More sharing options...
