Macleous Posted November 5, 2010 Share Posted November 5, 2010 Hey guys, I'm having problems with my 93 Legacy LS (EJ20). It starts up normally and idles high(1100-1500rpm), when I switch into drive/reverse the engine immediately bogs down and the rpms jump all over the place, I also have a huge loss in power, I mean I probably have <10%. I really need help with this and it seems like the engine is running on half the cylinders at times, I just replaced the spark plugs, wires and coils. There is also no CEL and after I drove it a bit with low power(had to get it back from the mall) the engine bay smelled strongly of burnt plastic. Thanks in advance Link to comment Share on other sites More sharing options...
bobec Posted November 5, 2010 Share Posted November 5, 2010 well i kinda had same problem, but i washed my engine at power wash and i got a bit of water in my spark plug wires.... so try cleaning the spark plug wires? or maybe you put something wrong? Link to comment Share on other sites More sharing options...
Macleous Posted November 5, 2010 Author Share Posted November 5, 2010 Hmm I'm not sure, I've checked connections a few times now and they seem to be fine, and when i say i JUST replaced them i mean a few weeks ago and its been running totally fine and then all of a sudden it just decided to fail on me Link to comment Share on other sites More sharing options...
PaladinXT Posted November 6, 2010 Share Posted November 6, 2010 IAC (Idle Air Controller)? I've seen many similar posts about those needing a good cleaning. Seems pretty straight forward. Reccommended that you remove it from the car, clean it with carb cleaner, reinstall. This way you can be sure it is good and clean. I may be doing this myself here soon since I think this car was rather neglected. Spark plugs first though since I just bought em Link to comment Share on other sites More sharing options...
Macleous Posted November 6, 2010 Author Share Posted November 6, 2010 Oh problem solved, just replaced the ignition module. Link to comment Share on other sites More sharing options...
