W1CKED Posted November 4, 2010 Share Posted November 4, 2010 I'm getting a set of Infamous Performance headlights, and my current headlights have R-Rev eyelids on them. Do you guys/gals know of any tricks (other than just pulling hard) for removing the eyelids? I understand that I'll need new 3M tape for the re-install... Thanks for any information you may be able to provide. Link to comment Share on other sites More sharing options...
mattg Posted November 4, 2010 Share Posted November 4, 2010 You need to heat them up first. A hairdryer would be a safe bet, then pull them off carefully. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted November 4, 2010 Share Posted November 4, 2010 And you could use waxed dental floss to help it along. Works good to cut the adhesive between the eyelid (or badgiing) without damaging the eyelid or the headlight. You will still need to remove the adhesive from the headlight and the eyelid. Link to comment Share on other sites More sharing options...
Drift Motion Posted November 4, 2010 Share Posted November 4, 2010 heat gun...works the wonders... Link to comment Share on other sites More sharing options...
W1CKED Posted November 4, 2010 Author Share Posted November 4, 2010 Thanks fellas! Link to comment Share on other sites More sharing options...
SpecBGuy Posted November 4, 2010 Share Posted November 4, 2010 after heating it use googone to take off left over sticky stuff Link to comment Share on other sites More sharing options...
mattg Posted November 4, 2010 Share Posted November 4, 2010 Just be careful if you use a heat gun. You're working with plastic that could easily be distorted. Link to comment Share on other sites More sharing options...
W1CKED Posted November 4, 2010 Author Share Posted November 4, 2010 Just be careful if you use a heat gun. You're working with plastic that could easily be distorted. Good call on that one! I've got a couple of different options...I was just concerned that I would snap them if I just tried ripping them off. Link to comment Share on other sites More sharing options...
